Yes you should be concerned. Noises are omens of things to come. This could be the tire, driveshaft bearing, wheel bearing, rear end gear noise, bevel gears, etc... Does it make the noise only under load or when you let up on the throttle? Does it make the noise when you lean or ride upright? If only when you lean, to what side. If you have a bike lift, put the bike in the air and then use straps to secure the bike. If no lift, get the rear wheel up off the ground higher than just the center stand. Perhaps a wide piece of wood under the stand. Block the front wheel and put a wire tie around the front brake handle. Get a automotive stethoscope from Harbor Freight for five bucks. Also buy a wheel chock for the front wheel if you don’t have one. In the next step, for safety sake, you must have someone help you. Then start the bike and put it in gear. Bring the bike up to the speed and rpm where you hear the noise. If you don’t hear anything, take a good look at the tire. If you do hear it, use the stethoscope to locate origin. If you only hear it under load, might not hear it on the stand. Here is a parts diagram to show where the driveshaft, bevel gears, and rear end bearings are located so you know where to listen. Needless to say, be careful doing this check and make sure the bike is secure. Good luck.
Shop online for OEM Drive Shaft/Final Gear parts that fit your 2001 Kawasaki VULCAN 750 (VN750-A17), search all our OEM Parts or call at (231)737-4542
www.kawasakipartshouse.com
Shop online for OEM Front Bevel Gear parts that fit your 2001 Kawasaki VULCAN 750 (VN750-A17), search all our OEM Parts or call at (231)737-4542
