1 - 11 of 11 Posts
I was looking into a vertical licence plate holder bracket axle mount off ebay but it looks like the rear end of the bike needs to come apart in order to install it. How mechanically inclined does one need to be to undertake this task? Anyone tried it? Experiences?
Its a little complex I had to reverse my axle to get it out further to clear my brake line But other than that its ok I also had to use washers to space it out just a little but I love the look Heres mine And the light is brighttt
Any issues with alignment, belt tension, etc afterwards?
On a side note BlackedOutVulcan, was your bike a 'SE' originally? I want to replace some of the chrome looking plastics on mine with black ones like you have. Any idea where I can find the black plastic pieces?
I've seen several of the SE black plastics on ebay recently. Might check there AZ
similar to the above example ... same mount different shaped light ... paid 105 off ebay ... I reversed the axle while doing the swap to a 230 and used a 18mm axle nut from mean cycles that works SUPERBLY ... I stayed away from washers and actually used an angle grinder on the inside of the plate mount to work around the funny shape of the belt tensioners and then touched them up with black paint ... i've actually seen some who just angle the license up which i didn't like ...
Looks good! And great looking swingarm bag, I just ordered mine this morning. Is yours the standard or the wider option?
Mine's the standard size. If you got the same, don't expect to be able to store awhole lot in there but it looks damn good and comes in useful for small things.
I ordered the standard as well, traditional saddle bags just don't look right on the Custom. I also ordered the smoked integrated taillight that I see you have as well. Wiring reasonable straight forward on that? I'm exceptionally retarded when it comes to things like wiring
Just for kicks. Here's my Kury side mount
1 - 11 of 11 Posts
