1 - 3 of 3 Posts
Hi, I just got the fuel tuner and planning to install. Not sure which are the injectors cables from the harness. Diagram says blue/green and blue/red..
My understanding is the cable its blue with a red stripe or a green stripe. Correct??
Because I also see a red/blue and green/blue cable, in this case red cable w/blue stripe and green cable with blue stripe...
they are in the same side of the bundle that goes to the ECU..
I want to mAke sure I 'm connecting it right..
Also want to know what is the right setting.. I have debaffled pipes and modified air box,(moved the opening to the front of the bike..) and removed secondary plates...
thanks...
Typical wire color coding nomenclature has the main wire color stated first and, if present, any tracer color (stripe) is then noted second. Good luck with your project. Let us know how it comes out.
1 - 3 of 3 Posts
