1 - 4 of 4 Posts
Are the front turn signals on a Nomad 1700 always lit, or are the only illuminated while blinking? My left side always stays lit, and the right side lights only when blinking.
You have amber/yellow running lights on the front..... Your right side has a bad bulb or wire/bulb socket issue.
That's odd. If you have the Kawasaki light bar you might want to check over the wire connections. I have had issues with the shoddy wiring in the turn signal housings.
BOTM Winner, April 2013
The front signal bulbs are dual filament, one for running and one for turn. One of them is PROBABLY burned out.
1 - 4 of 4 Posts
