Arai has taken the Signet-Q that we've all grown to love and made it even better with the addition of key new features. The Arai Signet-Q Pro Tour is pretty much the same as before only with a different liner, Pro Shade visor system, and ear pockets for your comm system.
Check out the item on our website at www.RidersDiscount.com! If you have anymore questions or would like to place an order, simply give MIKE a call at 866.931.6644 ext. 804. Is email more convenient? Send us a message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
The Sig-Q Pro Tour is a long oval fit with an additional 5mm of space front to back and a different shell shape that greatly reduces forehead pressure eliminating hot spots.
The new Pro Shade system is Arai's solution to the drop down visor while still maintaining a SNELL safety rating. What's better about the Pro Shade visor system than the other helmets with an internal drop down visor is that the Pro Shade visor can also be used as a helmet peak. Arai have designed this visor so that it is aerodynamically efficient in the up position. There is no additional buffeting noticeable when riding with it up. It automatically locks in place in the up position. To bring it down, simply pull the visor forward to unlock the visor and pull it down.
Inside you'll find a new Eco-Pure liner that is even better than before with advanced moisture wicking and anti-bacterial properties. Removable ear pockets allow you to insert your communications ear speakers into the liner without creating a pressure point on your ear. Ventilation is even better than before with greater control over the brow vents. Now you can raise them halfway to fine tune how much air you want passing through.
What do you think of the new features that Arai has added to the Signet-Q Pro Tour? Let us know in a comment below!
