1 - 1 of 1 Posts
Have some tables I worked up a while back that show calculated MPH based on engine RPM and gear, and I'd like to dial them in against actual values.
So, I think if someone so equipped would be so kind as to run it up to 2500 RPM in 5th gear and let me know what speed the GPS says, I'd sure appreciate it.
Suppose I'd also need to know your rear tire size and brand, and if you've done anything to change the drive ratio (different pulleys, Euro gears, etc.)
1 - 1 of 1 Posts
