1 - 10 of 10 Posts
Last year I replaced the stator and regulator with Rick's parts. Recently my low beam burnt out. I replaced it and the new bulb quickly fried, high and low. I tried another bulb with similar results. That led to testing of volts at battery and headlight with engine running. It was 17-19v, well above specs in manual indicating bad regulator. While I deal with the Ebay seller and warranty claim, I've started the bike again just to double check my findings. Tonight I started it with the regulator unplugged while taking a reading at the battery, then plugged the regulator in. The familiar noise I heard put a not in my stomach. It was the "stator going bad sound." Here are my questions...Did I damage the stator by plugging in a bad regulator with the bike running? Anyone else had problems with Rick's parts? Does a stator operating any length of time with a bad regulator tend to make it go bad? Or am I just really unlucky?
Am sure the bad regulator probably damaged the stator. Would check all wires going to the regulator for shorts or loose/corroded connections.
I replaced my stator and reg with Ricks 14 months ago. Ricks regulator went bad in about 6 months (thank you kuryakyn volt meter).
Sent it to them and they replaced it at no cost. However, I purchased an OEM regulator and that is what is on the bike now.
14,000 miles on Ricks stator at this time.
Rick's warranty
thanks for the reply gentlemen. Johnny, did you buy direct from Rick's? I'm starting to get the feeling I'll be jerked around. I followed up with my ebay seller and they said they, as in Rick's hadn't got back to them (seller) yet...
thanks, that's good to know for future reference. If I don't hear back from the seller Monday, I'll have to contact ebay and get them involved. In the meantime, I'm stuck buying two new parts because I want to get back on the road as soon as possible. This is quickly becoming a headache.
I took the chance in buying my stator off Ebay from Parts_giant but paid $134 instead of $160 direct from Rick's. It came in a Rick's box with their directions so I'm hoping I don't have a problem. I just installed it about 600 miles ago and its been fine and I did all the regulator tests and other stator tests after the stator install.
Just had a guy at work that had his Ricks regulator go out on his way in to work on Monday. He has had it on his bike for just a couple of months. His bike was not a kawi, it is a Yamaha I think.
I replaced my OEM with Rick's stator and regulator as a pair. That was 12000 miles ago. Both still running strong. But I did keep the OEM reg as a back up.
1 - 10 of 10 Posts
