1 - 5 of 5 Posts
Discussion Starter · #1 ·
One learns the value of this forum and all you fine folks the hard way, most often. Put 400 miles on my brand spanking new Voyager (21 model, just purchased 2 weeks ago), and somewhere between filling up in Aurora NE and my stop in Lincoln NE, the antenna fell off. I was running bluetooth so never noticed a drop in radio reception. I see it's happened to a lot of folks. It goes in soon as the dealer will give it a 500 mile inspection/fluid check etc, so hopefully they will replace the antenna that apparently was not on tight at all.
As bad luck goes on riding, it could be far worse...
I'm pretty sure I know where my original antenna is. Looks like my Vaquero uses the same part as your Voyager. If you need it, PM me. Mine's just sitting in a drawer. I replaced mine with this the first year I had it.
Tire Wheel Vehicle Automotive lighting Automotive tire
Had the same thing happen back in April after I first bought my 2021. Rode it home, the first ride to work...60 miles...arrived at work without the antenna. I called the dealership and gave them the part numbers...antenna and tip, and they ordered and installed during my first service, all free of charge.
Discussion Starter · #5 ·
Thanks for the offer, SteveJB, though after having the "500 mile checkup" yesterday, the dealer has a new one ordered so they will replace under warranty. Suffice to say there will be a lock washer and loctite applied this time... lol
1 - 5 of 5 Posts
