iz, on the side stand. no need for a lift. all yor strip is on the rite side.
as for Left Thread impact on the front k'nutt is the booger. a impact driver driver will bust it loose fine. If you prefer, use a 2ft breaker bar and put a soft copper penny between the teeth. I held it with side cut pliers so as not to drop/loose it. the penny locked the gears and the the k'nutt came loose w/o any fuss. no impact needed. Be sure to tape off the 2 openings to the tranny cavity. And dont loose the Pin & spring (gear positioner)
ps. I put the coin in the gear teeth HORIZONTAL, not vertical. this way the soft copper is under compression in the groove up the gears and not on the Teeth of the gears. is why it bent the coin as pictured. soft copper. also allows you to be able to hold it while wrenching.
