1 - 4 of 4 Posts
My wife has a 2012 VN900 Classic. The span between the grip and the clutch lever is a little too wide for her hand. She has the strength to pull in the lever, just needs to be closer to the grip. Tried adjusting the cable. It helped a little but not enough. Are there any adjustable levers or redesigned levers that would bling it closer to the grip. I tried searching and called a couple dealers with no luck. Thanks for the help.
The no-direct fit situation is what I've experienced as well. It appears that some adjustable levers probably would work but won't match the brake lever and/or would require some adaptive work to be done.
1 - 4 of 4 Posts
