That's the same issue I had. Bent shift fork.
This is the problem I had. The mechanic knew as soon as I described. I didn't mind because I had an internet diagnosis from Racnray with the same outcome.Just to be clear. It only stumbles in 2nd doing a hard acceration and always at 35 mph? It's only one quick buck and then its perfect? I can not duplicate this in any other gear or speed. Can this still be a bent shift fork?
Mine was only once and only in 2nd gear. An ignition miss would be constant because the ignition would keep missing (in my opinion). You can read about it here.Ignition miss, Is the direction I've been leaning. But wanted to hear from others with more experiance than I. Also if anyone had any thoughts as how to trace the problem. Thanks wrenchjockey for your input.
Good read Mr H, the only thing that had be perplexed was a comment about a hollow point? wtf is it and how would it have helped?You can read about it here.
It was a play on troubleshooting and trouble shooting. Like diagnosing (troubleshooting) and shooting with a gun (I was having trouble shooting [with a gun]).Good read Mr H, the only thing that had be perplexed was a comment about a hollow point? wtf is it and how would it have helped?
Ando
Ahhh, yeah I did the google thing later on wondering what it was, heck i didn't realise it was bullets, haha.It was a play on troubleshooting and trouble shooting. Like diagnosing (troubleshooting) and shooting with a gun (I was having trouble shooting [with a gun]).
My '07's been doing the similar thing and straight bogs and lurches like the guy was saying and it only started doing it after I had it painted and the tank wasn't covered right and so it clogged the filter and I changed the filter and pump and everything out and it still does it I pulse cleaned the injectors and for the life of me I cannot trace down the problem. What ended up being the problem on yours?Just to be clear. It only stumbles in 2nd doing a hard acceration and always at 35 mph? It's only one quick buck and then its perfect? I can not duplicate this in any other gear or speed. Can this still be a bent shift fork?
