1 - 10 of 10 Posts
Discussion Starter · #1 ·
Hi All,
I've run into a problem that I cannot seem to fix. This is a new purchase, think the bike sat for a period of time. Problem I am having is once I put the bike in gear and release the clutch the bike will stall. I first thought it was the kick stand switch but I ruled that out. I release the clutch about 80% then she dies on me. I almost feel like she isn't getting enough fuel once she is under distress.
Here is a list of things that I have done so far:
Applied generous amounts of Seafoam
Moderately cleaned the Carbs
Changed the Battery
I am replacing the air filter and giving her an oil change this week.
Any suggestions please send them my way!
Thanks,
Newbie
Discussion Starter · #3 ·
At first I bypassed and closed the circuit. But based on my limited knowledge of the switch the bike would stall as soon as the clutch was released. In my case i can get the gear to engage and begin pushing the bike but when it gets about 80% released it stalls.
1. Raise back wheel off of ground.
2. Start bike, and at idle, put in gear.
3. Release clutch and if engine quits, the fault lies with the interlock circuit.
4. If it does not, then the problem is elsewhere.
Post back with results.
How did you determine it was the diaphragm? What can I do to trouble shoot it. It makes sense its a fuel delivery problem and not electrical.
Honestly, we brought it to a shop. DH doesn't like to play with carbs and since it would only stay running with the choke out, he had a good idea that it was something with the carbs.
The guy at the shop said these bikes don't like to sit.
1 - 10 of 10 Posts
