1 - 2 of 2 Posts
Scott, What are you going to do with the old engine ?
I have been trying to get an old engine into my shop for some serious upgrade R&D work, but, I need it on the cheap ! I would require the cases, cylinders, and heads for what I need to do. The cases could be gutted or intact, don't matter.
What I want to do is to digitize the intakes both while assembled and apart then make jigs to hold heads for machining of intake port for larger bore and different mounting and since I am going to be changing the Geometry a lot in the intake I need a good probing of the heads bolted down in place for the stock Geometry's.
1 - 2 of 2 Posts
