1 - 3 of 3 Posts
I recently replaced the plugs and battery because my bike wouldnt start at all unless hooked up to a battery tender. Now the bike starts every time, but in the low RPM range, I am getting a lot of miss fire and hesitation. The carbs were just cleaned and rebuilt, but I do not think they were synced. Could the carbs not being synchronized cause this? Or is there some other problem I am over looking? Any help would be appreciated. Thanks
Check plug wires and caps while parked in a dark area, for arcing and broken insulation.
Try spraying a light water mist around the wires if needed.
Double check new battery for proper terminal voltage. Occasionally a new batttery can be bad.
You can make an inexpensive but functional manometer with a yardstick, 10' of 1/4 inch clear plastic hose, a few zip ties and a few ounces of ATF to sync the carbs yourself.
You can try a simpler check first though. Check to see that both throttle levers on the right side of the carb are starting to move at the same time.
1 - 3 of 3 Posts
