1 - 5 of 5 Posts
So i just picked up this bike and i got the carbs clean, but now can't figure out how to reinstall them in the bike, the throttle linkage hits the cyl. head no matter how I turn it... So do I just need a real big shoehorn and some axle grease or what?
Discussion Starter #2
Ok, I've got the carbs back on and the carb boots tightened up, now I'm just trying to figure out where everything goes, as I got the bike with a few things removed by the PO. Coming from the center plate that holds the two carbs together are 4 hoses, 2 of which are for incoming fuel, that connect to the petcock valve, which are located closer to the front and back, but the other 2 go into a T-fitting above the carbs. Where does this T-fitting go to? Or is it supposed to be left open like a breather or something?
This pic shows the T-fitting, circled in red. (Again, not sure if that is where it is supposed to be, that is just where it was located when I got the bike)
Any help or a hose routing schematic would be greatly appreciated.
1 - 5 of 5 Posts
