1 - 9 of 9 Posts
Just did an oil change with the recommended oil, Lucas semi synthetic for wet clutches not Kawasaki, and a k&n oil filter. Have not a problem in 200 miles or so until the other night during a bike night I was getting on it heavy and hit 3rd gear and there was a good deal of slipping going on. Not terrible bad but definitely noticeable. I guess my questions would be has anyone else had this problem on any bike, and how could a clutch be slipping at 17.5k miles. The bag has been gotten on from time to time but usually ridden just cruising. Am very confused have never had just 1 gear slip, all other gears are fine. Any help would be greatly appreciated.
Also be sure you did not hit the rev limiter.I would wind it up again to be sure it is truly slipping.Often times though when a clutch begins to slip it will be in the higher gears.
That's what I figured I have never had 1 gear slip, I am going to get a new clutch cable I think it is something to do with that because if I power shift it (just did it a couple times today) it is just fine. Just strange it is only 3rd gear.
Sorry power shifting is not using the clutch. I think maybe I am just getting out of my power and and then back in it and it feels and sounds like slipping.
Edge of the power band apparently feels like slipping clutches. Will update more if I find anything else out testing is not finished.
1 - 9 of 9 Posts
