1 - 5 of 5 Posts
After a bit of research looks like the +1 front pulley is no longer made for the V2K which sucks for two reasons.
#1 reason. I run a car tire and a inside the fender hitch and if were not for the 33 tooth pulley I would not have enough clearance between the tire and hitch . So when my pulley wears out I'm back to MTs and crappy tire life.
#2 reason A buddy of mine wants to put a CT on his V2K and he has a hitch as well. He has a different brand of hitch so he may get lucky and not need a 33 tooth pulley but just by looking at it I'm guessing he will.
Anyone have a good 33 tooth front pulley they want to sale or have a lead on where a guy can still get them?
I don't understand how the front pulley has anything to do with tire/hitch clearance.
Bigger pulley takes up more belt so when adjusted the axel will sit a little bit forward of what it would with the OEM pulley which in turn pulls the rear tire forward and away from the hitch
Oh, ok. Thanks.
You can fix that with a different size tire. What are you running now?
If you are running a 205/60 you can go to a 205/55 and reduce your sidewall height by 11mm. Is that enough clearance?
1 - 5 of 5 Posts
