Do you guys just replace the crush washer now & then ?
Where did you buy them ?
Have any of you bought spare plugs/washers ?
If so were they OEM ?
Expensive ?
Are they all the same ?
Where is a great place to get the 3 plugs & crush washers ?
I need them for the V2k,Stratoliner,& Valkyrie.
I found these expensive ones: :eek: http://www.magneticdrainplug.com/motorcycle.html
At $15 bucks a pop are they worth it ?
JJ
I have always reused them. I have done 2 changes on the V2K so far and it has not started leaking yet. I guess I will get some new ones if they start leaking or I lose them. :D. I guess it would not hurt to have some of the gaskets on hand though.
V2K Rogue Wrangler
I bought spares from BikeBandit.com. They were not too expensive. I had to replace the flanged plug because it was cracked. I reuse all the seals and plugs but I have a complete extra set just in case.
Sent from Motorcycle.com App
Size
Hmm... magnetic drain plugs. Kind of nifty.
(I'm sure that's why they are expensive there..stock ones not magnetic. Also remember the 2 oil plugs in the pan on these V2k's are not the same size. )
Not the same size ?
Same thread ? Longer/shorter ?
Cheaper ?
JJ
