Why wouldn't use go ahead and make the change to synthetic now? Just wondering....
I've always thought you were supposed to use regular dino oil thru break-in before switching to synthetic. No?Why wouldn't use go ahead and make the change to synthetic now? Just wondering....
I'm not offering opinions, I'm asking. I'm almost ready to do a first service on a new 2013 Voyager, but I was planning to use synthetic in the service.I've always thought you were supposed to use regular dino oil thru break-in before switching to synthetic. No?
When I did the first oil change on my 2013 Voyager I went right to synthetic. I'm using Amsoil 10W40 with a K&N 303 filter. I like the nut.I've always thought you were supposed to use regular dino oil thru break-in before switching to synthetic. No?
Any suggestions to help me make the first oil filter removal easier? Plan on getting a strap wrench but other than that?After the first oil change on mine, I immediately switched tot he K&N filter . . . Getting the filter off the first time was an experience I do not want to have to replicate . . . .
I can't say that I did. I bought a couple of strap wrenches today, small & large.You can use the strap wrench in either direction.
You know that right?
I changed to Amsoil at 600, next change at 6000, and again at 12000. Didn't have to add any in between. I've never been able to consistently get the same reading on the dipstick too. Sometimes a little higher, sometimes a little lower. As long as it is between the tic marks, good to go.I kept dyno oil in mine for 5000 miles. Then switched to mobil 1.
http://www.walmart.com/ip/Oil-Filte...-1-2-Heavy-Duty-Vinyl-Coated-Handles/41094105
I use Oil Filter Pliers to remove and my hand to put on a new one.
I do like the K&N filters, but got a bunch of Kawasaki filters at cost when my local dealer was going out of business.
I have heard that these engines aren't really broken in until 5000 miles and didn't want to risk using any oil during break in. Even when I switched to synthetic at 5000 miles, I did have to add a little oil before the next oil change and from there on I was good. Now have about 50,000 on the bike.
No it's not too high. Within the hash marks is good.All went well with the oil change. I thought the oil drain plugs didn't have washers on them but they had fallen into the used oil pan. Filter came off fairly easy with the small strap wrench. Took my time moving the bike from kick stand to straight up, back and forth until I was sure all the oil was out. Had a friend watching when no more oil was coming out helped a lot. Added 4 qts then started engine, and followed book to check level. Ended up adding another full quart to make it 5 total. The oil mark is about 3/4 up the cross hatch. Is that too high? I would have rather it been about 1/2 way.
I have wanted to do the Commander II's on my Voyager, but can't find them in the stock tire size. Even went on the Michelin site and they said they make tires foe over 3000 bikes, unfortunately not this one. If you put Commander II's on your bike please advise on what size you used and if you are experiencing any issues.When I did the first oil change on my 2013 Voyager I went right to synthetic. I'm using Amsoil 10W40 with a K&N 303 filter. I like the nut.. Went 6k miles to the second change. I'll keep doing it every 6k. Makes the figuring out when I did the last change a lot easier. I subscribe to the KISS principal. In a couple weeks I'll be installing Commander II's front and rear. I'll be doing Rolling Thunder again this year and another trip (3d) to Canada.
those are what I put on my Voyager with no issues, as most others have done.Your asking about CIIs in an oil thread? Lot's of info if you just search on Commander IIs. But I'll save you the time..
Front- 130/90 B16
Rear- 180/65 B16
