1 - 3 of 3 Posts
Thank you in advance for your expertise on this issue.
I've heard the Voyager handlebar will work on the 2012 Nomad and that the grips are a little closer together.
1. Is the Voyager bar the same diameter as the Nomad stock handlebar? How much does Kawasaki usually charge for it?
2. Also, does the Voyager bar put the grips farther back towards the rider or are they about the same?
3. Rerouting of cables a total PITA? anything need disconnecting or can I just route them behind the tree if needed?
4. Backrests: Anyone have experience with Bakup products?
5. Who makes a good footpeg for the highway bars. What is the bar's diameter?
Thank you, I'm sure many of you have felt the pain of "fitting" a bike to you once you buy it. I don't want to make a costly mistake of buying the wrong accessories.
Ride Safe!!
Buy risers for your handle bars, much cheaper than changing out the whole handle bars. I believe the bar is 1-1/4" and alot of riders use the Kuryakyn brand and there is a post on the same page as yours that talks about them, see Longhorn Offset Dually Highway Pegs
try these
http://www.shopscootworks.com/ScootWorks-Scootworks-ExtendRiser-Kit-For-Vulcan-1700-detail.htm?productId=-143813&catalogId=&searchProducts=1700 nomad
ohttp://www.shopscootworks.com/RISERS-1700-CLASSIC-LT-NOMAD-VOYAGER-VAQUERO-detail.htm?productId=-143815&browse=-20181&shopBy=-3244&catalogId=-799r I have the second ones on my voyager 2inch up and 2inch back. They are great after getting them installed. Will have to reroute the brake line behind the triple tree. A lot of guys have had problems with timely shipping from scoot works. It took me 2 weeks to get them after I ordered them.
1 - 3 of 3 Posts
