2006 Vulcan Nomad 1600 with electric issue. Just bought it. Has 55,000 miles. Runs great. Guy said he had just put a battery in it but after wards lost the radio on the aftermarket fairing. Also the high beam and neutral light are not coming on. Started tracing issues. Fairing is wired to under the seat for constant power and ground and one wire into headlight bucket that works as ignition. So after opening headlight bucket and fairing everything looked good and found the fairing wasn’t getting ground. Traced it back to under the seat. The ground is tied into a yellow with black strip wire that is with a 4 prong green plug that has rubber plugs like nothing plugs to it. Maybe for another option or something? Anyway there is no ground on that wire. Can’t find nothing unhooked and the yellow wire goes into main harness. Hooked the fairing wire to a good ground and radio and usb works with switch like it should.
My question is since this wire that used to have ground doesn’t anymore could it be anything to do with neutral light and high beam light? I tried giving it ground to like back feed maybe but didn’t fix indicator lights. Everything works. Bike runs. High and low beam work. Stand switch works. Just not the neutral and high beam indicator. Wouldn’t worry to much but has to have that blue indicator to pass inspection.
Any ideas anyone?
Any ideas anyone?
