1 - 13 of 13 Posts
Found a 05 1600 classic for sale for 1500 bucks. Ive got a 02 1500 classic been riding for 4 years. Found this 05 1600 and it has 48000 miles on it. I would like to have a 2 up bike for the wife and I and have the 1500 for single rider.
Should I be alarmed at near 50000 miles? When I look at this bike is there any thing I should look for as something that might be a problem. I had the relay for headlight go out on my 1500 but other than that its been great to me.
Any information about the 05 1600 would be greatly appreciated. thanks
Discussion Starter #2
no clues out there on the 1600 classics?
Besides the usual wear and tear items, there is a sometimes sore spot with the bevel gear case bearing.
The symptom is a whine when de-accelerating.
$1500 seems pretty cheap, so there must be a reason for that.
Thanks for the heads up on that bearing. I appreciate it.
Another issue is grinding or jumping out of second gear, but that is not limited to the 1600.
Many bikes may suffer from this problem.
I've got 73000 KM on mine, no issues, I've had to tighten the triple tree nut once. Rear shocks might be an issue, I upgraded to progressives.
I bought an 07 Nomad in April with 75,000km (roughly 48,000 miles). It needed the steering bearings replaced, and a fork seal started leaking. Nothing out of the ordinary for the mileage. Clutch will soon need replacing too, but again, that's not unusual for the mileage. I now have almost 79,000 on it and no other issues. Engine performs flawlessly and everything feels tight.
Even with a bevel gear issue this seems like a decent price if its in good shape physically..
i paid $2800 for a 2009 classic 1700 LT with 7800 miles
Guy wanted $4200 and I said I wouldn't pay a dime over $3700
He called me back 2 weeks later and said he'd take $3000 and I said all I have is $2800
He said sold!!!
I needed new tires and they were about $220 on amazon with white walls. Full synthetic oil with filter was about $50 @ walmart.
I think I have a valve that needs to be tightened. I hear a rattle when I'm going 35 in 3rd or 45 in 4th. I read that a loose valve isn't as bad as a tight valve, you just loose a little bit of mileage that's all. I'll probably fix it when it's stored for the winter.
1 - 13 of 13 Posts
