1 - 5 of 5 Posts
1 post 5 minutes ago Parking lights and break lights wont work but it will start and run. The lights will work with the switch in park position. I'm thinking bad ignition switch...any in put would be appreciated
Someone correct me if I'm wrong, but I'm looking at some wiring diagrams for the 04 1500's and some models seem to not have a running light circuit. Double check your light connections and bulbs, and see if there actually is a running light circuit.
It would help to know your sub-model.
:cheers:
On my way back to the house right now and will check but why would they work with key in park position and not the run position if it was a ground or fuse?
1 - 5 of 5 Posts
