1 - 12 of 12 Posts
I just changed the starter solenoid relay on my wife's Vulcan 500 the problem was is that we get a one click when we try to start it after replacement of the battery and this new solenoid we're still at the same problem any help would be grateful
Load test the battery first.
Yes I know its a new one, please load test it.
Next with a meter measure the battery voltage with the key on and,
when you push the start button.
Post back results.
Well we push started the bike and rode it for a while shut it off and it starts again I don't know what to say we're going to let it sit for a couple hours and see if it starts
Update we bought a new battery and charged it and still get a click. The bike sat for 5 minutes and wouldn't restart.
This is what worked for my '94 when it started clicking - not sure how much changed between '94 and '96.
Measure the resistance through the starter motor - if it's over 1 ohm or so (mine was 5) the starter is messed up, since a properly operating starter draws some number of 10s of amps; at 12v that means a resistance of well under 1ohm. Pull the starter, pull it apart, clean a bit between the copper parts in the commutator, see if any of the brush springs are not working and wiggle them a bit, etc., then put it together and see if the resistance is back down to a reasonable range.
Then do what I did and buy a rebuild kit ($20-$30) and budget an hour sometime to pull it off the bike all over again, because the brushes probably don't have much life left in them and the O-rings are probably shot. I'd suggest doing what I did and throw away the replacement bushings and bearings - I would bet an amateur job of replacing them is worse than leaving the old ones, while replacing the brush assembly and O-rings is quite easy.
If the resistance is high, then the starter is messed up - pull it and take a look, per the directions above.
If it's not, then keep looking...
Before you pull the starter, make sure the contacts inside the starter button are clean. My bike would make a clicking sound when I tried to start it, as if the battery was dead. There is a small spring inside the assembly so be careful when you take it apart. Clean the contacts with some sandpaper and apply a small amount of dielectric grease to the contacts.
Have you checked the tightness of the battery post adapters? If not there is a 'sticky' at the top of this form telling about them and how to check/tighten them.
1 - 12 of 12 Posts
