1 - 3 of 3 Posts
Discussion Starter · #1 ·
I recently purchased a 2009 VN1700 without a key. The original check-off sheet from the original dealership was in the trunk with the key code on it. I had a locksmith make a couple keys. The problem: the keys work in the fuel tank and in the cubbies in the fairing. The key will go into all the other locks but not turn. The locksmith said it felt like the lock wasn't stuck but needed a different key. Any suggestions???
The key's not cut properly. It's supposed to insert about 1/2" deeper into the ignition than the various locks. My Vaquero came with two keys, but they are both the same. When I had one made, it was at a Kawi dealer. They used the key code and it worked perfectly.
1 - 3 of 3 Posts
