1 - 1 of 1 Posts
So when I had the motor out over the winter I put some RVT on the front head where I was leaking oil, as suggested from users here.
Apparently I didnt go deep enough because, as you can see in these photos, the oil isnt leaking between the valve cover and head, but instead that circular piece in the center (not sure what its called?).
Whats the solution? Ride it as is until I can get the motor out and re-do it? Is it even possible to fix? Ive put about 500 miles on it since I got it back on the road and have been pretty diligent in regards to keeping an eye out for any issues. The oil I saw this morning is way more than it had been leaking prior, so not sure what to do, and the oil on the frame hasn't happened up until today.
http://imgur.com/CgcNpg8&XhpzTs5&LQarj35&K7KljXg&163JLnP&9AuGXfD
Thanks for taking a look.
1 - 1 of 1 Posts
