1 - 2 of 2 Posts
I don't believe you can do that with out changing your forks as well, that leads to Triple tree change too. Forks on both Vulcans will be different diameters. Also brake calipers will not mount the same either. Nothing is every as easy as it sounds. If you want you can do some research on this website to see actual parts diagrams.
http://www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
1 - 2 of 2 Posts
