1 - 5 of 5 Posts
My Clymer manual electrical diagram is incorrect and impossible to use to track down the problem I am having (starter relay is not pulling in). Is there a complete (accurate) electrical schematic available online?
Had a few more thoughts on this matter this morning.
There are several safety switches in the starting and running circuits
Engine stop switch on right handlebar- is it in the RUN position?
Starter lockout switch on the clutch lever
Neutral lockout switch
Sidestand lockout switch.- Can get jammed with small stones or dirt. Put bike on centerstand, raise sidestand and spray switch with WD-40. Wiggle switch lever around until it moves freely. Test starter again.
If the side stand is down, the safety switch will not allow the start or run circuit to operate if the tranny is in gear, even if the clutch is pulled in.
1 - 5 of 5 Posts
