So I have a bit of a mystery on my hands and I am wondering if any fellow 1700 riders have had this experience or may be able to offer up some clues as I am running out of theories myself. I have a 09 1700 Nomad that appeared to have an oil leak coming out of the lower left side of the engine. I noticed it after few days of the bike sitting in the garage. There were a few oil drops on the floor and a little oil moisture accumulated on the undercarriage. The oil level was a bit lower as well (not surprising), so I filled it back up, cleaned up the engine and kept an eye on it.
But over the the next week or so the leak appeared to have disappeared. No drops, no moisture on the engine. I checked the oil level though and it was almost down to the tip of the stick! I filled it back up with nearly 36oz of oil to get it back the previous level (75% of the fill level) and kept it in the garage (on the lift) for a week WITHOUT RUNNING IT at all. I checked it again and low and behold the same result! No drips or moisture but the oil level had declined by about a quart. This time I filled it up again but included 1 oz of UV dye to help highlight where any leaks may be. However now a week later (after only running it once to mix the dye) the floor and engine exterior are still bone dry and I can’t confirm how/where the oil is draining or where it is going. I’ve checked the coolant and around the oil pump cover but no sign of oil. I figure by now I’ve put almost 3.5 quarts in the engine over the last 3 weeks to keep it level so unless somebody is coming in my garage at night and siphoning it, I really can’t explain HOW THIS IS HAPPENING.
Has anyone else had this experience? Or have any ideas?
The only other thing I can think of to try at this point is to drain the oil completely (or just wait) and do a smoke test. What do you think?
