So I have read most of the "bike won't start" threads and am slowly troubleshooting this issue.
Bought new battery last night and am using a fluke true rms meter.
Key off - 12.61vdc
Key on - 12.35vdc
Key on 5 mins 12.32vdc
Start button - 12.19vdc
When the key turns to on, fuel pump starts. When start button is pushed, solenoid clicks but nothing to starter. Clutch switch and kickstand switched are bypassed temporarily.
Neutral light is on and oil light (this is normal iirc?) what should I check next?
I appreciate any insight you have. I'm an HVAC service tech and troubleshoot but I deal mainly with ac voltage.
On the positive side of the solenoid, you will always have battery voltage. When you press the start button and the solenoid clicks, do you have voltage on the terminal with the cable going to the starter? If not appears your solenoid is not working.
Pretty sure it's the starter solenoid. The Cycle Specialties guy tells me the vn1500 L is a different solenoid but couldn't tell me how or what's different. Took my tank off, dumped old gas, put in new gas, jumped the coil and it starts and runs.
Anyone know what's different about the S1?
Here is a list of where your starter solenoid is used: Assemblies where 27010-1347 is used
1995 GPZ1100 (ZX1100-E1) - Starter Motor
1996 GPZ1100 (ZX1100-E2) - Starter Motor
1996 GPZ1100 ABS (ZX1100-F1) - Starter Motor
1996 VULCAN 1500 CLASSIC (VN1500-D1) - Starter Motor
1996 VULCAN 500 LTD (EN500-C1) - Starter Motor
1997 GPZ1100 (ZX1100-E3) - Starter Motor
1997 VULCAN 1500 CLASSIC (VN1500-D2) - Starter Motor
1997 VULCAN 500 LTD (EN500-C2) - Starter Motor
1998 VULCAN 1500 CLASSIC (VN1500-E1) - Starter Motor
1998 VULCAN 500 LTD (EN500-C3) - Starter Motor
1999 VULCAN 1500 CLASSIC (VN1500-E2) - Starter Motor
1999 VULCAN 500 LTD (EN500-C4) - Starter Motor
1999 VULCAN NOMAD (VN1500-G1) - Starter Motor
1999 VULCAN NOMAD (VN1500-G1A) - Starter Motor
2000 VULCAN 1500 CLASSIC (VN1500-E3) - Starter Motor
2000 VULCAN 500 LTD (EN500-C5) - Starter Motor
2000 VULCAN NOMAD (VN1500-G2A) - Starter Motor
2000 W650 (EJ650-A2) - Starter Motor
2001 VULCAN 1500 CLASSIC (VN1500-E4) - Starter Motor
2001 VULCAN 500 LTD (EN500-C6) - Starter Motor
2001 VULCAN NOMAD (VN1500-G3) - Starter Motor
2001 W650 (EJ650-A3) - Starter Motor
2002 VULCAN 1500 CLASSIC (VN1500-E5) - Starter Motor
2002 VULCAN 500 LTD (EN500-C7) - Starter Motor
2002 W650 (EJ650-A4) - Starter Motor
2003 VULCAN 1500 CLASSIC (VN1500-E6) - Starter Motor
2003 VULCAN 500 LTD (EN500-C8) - Starter Motor
2004 VULCAN 1500 CLASSIC (VN1500-E7) - Starter Motor
2004 VULCAN 500 LTD (EN500-C9) - Starter Motor
2005 VULCAN 500 LTD (EN500-C10) - Starter Motor
2006 VULCAN 500 LTD (EN500C6F) - Starter Motor
2007 VULCAN 500 LTD (EN500C7F) - Starter Motor
2008 VULCAN 500 LTD (EN500C8F) - Starter Motor
2009 VULCAN 500 LTD (EN500C9F) - Starter Motor
2019 W800 CAFE (EJ800CKF) - Starter Motor
Mine calls for the 27010-0786. Not sure the difference
27010-0786 has been superseded by 27010-1327, here is a list of all that interchange with that #
Assemblies where 27010-1327 is used
1994 NINJA ZX-9R (ZX900-B1) - Starter Motor
1995 NINJA ZX-6R (ZX600-F1) - Starter Motor
1995 NINJA ZX-9R (ZX900-B2) - Starter Motor
1996 NINJA ZX-6R (ZX600-F2) - Starter Motor
1996 NINJA ZX-7R (ZX750-P1) - Starter Motor
1996 NINJA ZX-7RR (ZX750-N1) - Starter Motor
1996 NINJA ZX-9R (ZX900-B3) - Starter Motor
1997 NINJA ZX-6R (ZX600-F3) - Starter Motor
1997 NINJA ZX-7R (ZX750-P2) - Starter Motor
1997 NINJA ZX-7RR (ZX750-N2) - Starter Motor
1997 NINJA ZX-9R (ZX900-B4) - Starter Motor
1998 NINJA ZX-7R (ZX750-P3) - Starter Motor
1999 NINJA ZX-7R (ZX750-P4) - Starter Motor
1999 VULCAN 1500 DRIFTER (VN1500-J1) - Starter Motor
1999 VULCAN 800 DRIFTER (VN800-C1) - Starter Motor
1999 ZRX1100 (ZR1100-C3) - Starter Motor
2000 NINJA ZX-12R (ZX1200-A1) - Starter Motor
2000 NINJA ZX-7R (ZX750-P5) - Starter Motor
2000 VULCAN 1500 CLASSIC FI (VN1500-N1) - Starter Motor
2000 VULCAN 1500 DRIFTER (VN1500-J2) - Starter Motor
2000 VULCAN 1500 NOMAD FI (VN1500-L1) - Starter Motor
2000 VULCAN 800 DRIFTER (VN800-C2) - Starter Motor
2000 ZRX1100 (ZR1100-C4) - Starter Motor
2001 ELIMINATOR 125 (BN125-A4) - Starter Motor
2001 NINJA ZX-12R (ZX1200-A2) - Starter Motor
2001 NINJA ZX-7R (ZX750-P6) - Starter Motor
2001 VULCAN 1500 CLASSIC FI (VN1500-N2) - Starter Motor
2001 VULCAN 1500 DRIFTER (VN1500-R1) - Starter Motor
2001 VULCAN 1500 NOMAD FI (VN1500-L2) - Starter Motor
2001 VULCAN 800 DRIFTER (VN800-E1) - Starter Motor
2001 ZRX1200R (ZR1200-A1) - Starter Motor
2002 ELIMINATOR 125 (BN125-A5) - Starter Motor
2002 NINJA ZX-7R (ZX750-P7) - Starter Motor
2002 VULCAN 1500 CLASSIC FI (VN1500-N3) - Starter Motor
2002 VULCAN 1500 DRIFTER (VN1500-R2) - Starter Motor
2002 VULCAN 1500 MEAN STREAK (VN1500-P1) - Starter Motor
2002 VULCAN 1500 NOMAD FI (VN1500-L3) - Starter Motor
2002 VULCAN 800 DRIFTER (VN800-E2) - Starter Motor
2002 ZRX1200R (ZR1200-A2) - Starter Motor
2002 ZZR1200 (ZX1200-C1) - Starter Motor
2003 ELIMINATOR 125 (BN125-A6) - Starter Motor
2003 NINJA ZX-6R (ZX636-B1) - Starter Motor
2003 NINJA ZX-6RR (ZX600-K1) - Starter Motor
2003 NINJA ZX-7R (ZX750-P8) - Starter Motor
2003 VULCAN 1500 DRIFTER (VN1500-R3) - Starter Motor
2003 VULCAN 1500 MEAN STREAK (VN1500-P2) - Starter Motor
2003 VULCAN 1500 NOMAD FI (VN1500-L4) - Starter Motor
2003 VULCAN 1600 CLASSIC (VN1600-A1) - Starter Motor
2003 VULCAN 800 DRIFTER (VN800-E3) - Starter Motor
2003 ZRX1200R (ZR1200-A3) - Starter Motor
2003 ZZR1200 (ZX1200-C2) - Starter Motor
2004 ELIMINATOR 125 (BN125-A7) - Starter Motor
2004 NINJA ZX-6R (ZX636-B2) - Starter Motor
2004 NINJA ZX-6RR (ZX600-M1) - Starter Motor
2004 VULCAN 1500 DRIFTER (VN1500-R4) - Starter Motor
2004 VULCAN 1500 NOMAD FI (VN1500-L5) - Starter Motor
2004 VULCAN 1600 CLASSIC (VN1600-A2) - Starter Motor
2004 VULCAN 1600 MEAN STREAK (VN1600-B1) - Starter Motor
2004 VULCAN 2000 (VN2000-A1) - Starter Motor
2004 VULCAN 800 DRIFTER (VN800-E4) - Starter Motor
2004 ZRX1200R (ZR1200-A4) - Starter Motor
2004 ZZR1200 (ZX1200-C3) - Starter Motor
2005 ELIMINATOR 125 (BN125-A8) - Starter Motor
2005 VULCAN 1500 CLASSIC (VN1500-N4) - Starter Motor
2005 VULCAN 1500 DRIFTER (VN1500-R5) - Starter Motor
2005 VULCAN 1600 CLASSIC (VN1600-A3) - Starter Motor
2005 VULCAN 1600 MEAN STREAK (VN1600-B2) - Starter Motor
2005 VULCAN 1600 NOMAD (VN1600-D1) - Starter Motor
2005 VULCAN 2000 (VN2000-A2) - Starter Motor
2005 VULCAN 2000 LTD (VN2000-D1) - Starter Motor
2005 VULCAN 800 DRIFTER (VN800-E5) - Starter Motor
2005 ZRX1200R (ZR1200-A5) - Starter Motor
2005 ZZR1200 (ZX1200-C4) - Starter Motor
2006 ELIMINATOR 125 (BN125A6F) - Starter Motor
2006 VULCAN 1500 CLASSIC (VN1500N6F) - Starter Motor
2006 VULCAN 1500 CLASSIC (VN1500T6F) - Starter Motor
2006 VULCAN 1600 CLASSIC (VN1600A6F) - Starter Motor
2006 VULCAN 1600 CLASSIC (VN1600E6F) - Starter Motor
2006 VULCAN 1600 MEAN STREAK (VN1600B6F) - Starter Motor
2006 VULCAN 1600 MEAN STREAK (VN1600F6F) - Starter Motor
2006 VULCAN 1600 NOMAD (VN1600D6F) - Starter Motor
2006 VULCAN 1600 NOMAD (VN1600G6F) - Starter Motor
2006 VULCAN 2000 (VN2000A6F) - Starter Motor
2006 VULCAN 2000 CLASSIC (VN2000E6F) - Starter Motor
2006 VULCAN 2000 CLASSIC LT (VN2000F6F) - Starter Motor
2006 VULCAN 2000 LIMITED (VN2000D6F) - Starter Motor
2006 VULCAN 800 DRIFTER (VN800E6F) - Starter Motor
2006 VULCAN 900 CLASSIC (VN900B6F) - Starter Motor
2006 VULCAN 900 CLASSIC LT (VN900D6F) - Starter Motor
2007 ELIMINATOR 125 (BN125A7F) - Starter Motor
2007 VULCAN 1500 CLASSIC (VN1500N7F) - Starter Motor
2007 VULCAN 1500 CLASSIC (VN1500N7FA) - Starter Motor
2007 VULCAN 1600 CLASSIC (VN1600A7F) - Starter Motor
2007 VULCAN 1600 CLASSIC (VN1600A7FA) - Starter Motor
2007 VULCAN 1600 MEAN STREAK (VN1600B7F) - Starter Motor
2007 VULCAN 1600 MEAN STREAK (VN1600B7FA) - Starter Motor
2007 VULCAN 1600 NOMAD (VN1600D7F) - Starter Motor
2007 VULCAN 1600 NOMAD (VN1600D7FA) - Starter Motor
2007 VULCAN 2000 (VN2000A7F) - Starter Motor
2007 VULCAN 2000 CLASSIC (VN2000E7F) - Starter Motor
2007 VULCAN 2000 CLASSIC LT (VN2000F7F) - Starter Motor
2007 VULCAN 900 CLASSIC (VN900B7F) - Starter Motor
2007 VULCAN 900 CLASSIC LT (VN900D7F) - Starter Motor
2007 VULCAN 900 CUSTOM (VN900C7F) - Starter Motor
2008 VULCAN 1500 CLASSIC (VN1500N8F) - Starter Motor
2008 VULCAN 1500 CLASSIC (VN1500N8FA) - Starter Motor
2008 VULCAN 1600 CLASSIC (VN1600A8F) - Starter Motor
2008 VULCAN 1600 CLASSIC (VN1600A8FA) - Starter Motor
2008 VULCAN 1600 MEAN STREAK (VN1600B8F) - Starter Motor
2008 VULCAN 1600 MEAN STREAK (VN1600B8FA) - Starter Motor
2008 VULCAN 1600 NOMAD (VN1600D8F) - Starter Motor
2008 VULCAN 1600 NOMAD (VN1600D8FA) - Starter Motor
2008 VULCAN 2000 (VN2000G8F) - Starter Motor
2008 VULCAN 2000 CLASSIC (VN2000H8F) - Starter Motor
2008 VULCAN 2000 CLASSIC LT (VN2000J8F) - Starter Motor
2008 VULCAN 900 CLASSIC (VN900B8F) - Starter Motor
2008 VULCAN 900 CLASSIC LT (VN900D8F) - Starter Motor
2008 VULCAN 900 CUSTOM (VN900C8F) - Starter Motor
2009 ELIMINATOR 125 (BN125A9F) - Starter Motor
2009 VULCAN 2000 (VN2000G9F) - Starter Motor
2009 VULCAN 2000 CLASSIC (VN2000H9F) - Starter Motor
2009 VULCAN 2000 CLASSIC LT (VN2000J9F) - Starter Motor
2010 VULCAN 2000 CLA
