Hey I’m new here and have had my 06 Vulcan 900 for a few months now. I noticed about a month ago while riding at night my headlight appeared to dim out slightly then get bright again. When it first started I thought my eyes were playing tricks on me. Fast forward you tonight, it became very noticeable so I bought a new bulb think the low beam side was getting ready to fail. I put a new bulb in and went for a ride and 5 min in it blew both sides of the bulb. I got the bike home and put a meter on the battery and at idle (slow) I’m getting about 12.98V but under acceleration the meter climbed to 18V!!!! I shut the bike off so I don’t blow anything else. Thoughts? Regulator? Stator? Short? Any help is appreciated.
The 900's are known for stator issues. But what you're describing sounds a lot like a regulator problem. The only way to know for sure is to test the entire charging system. There used to be a stator thread in the forums that detailed how to do that. I don't know if that would be any help or not. I've never had that problem with mine. I had a bad stator twice.
Sent from my SAMSUNG-SM-G935A using Tapatalk
I may have gotten very lucky. The guy I bought this from had replaced the stator/regular with a kit from eBay and he gave me the old bad parts. I just happened to save the “bad” regulator and for kicks I swapped it out and now am running between 12.98 and just under 14 volts across the battery.
That's good news. I've heard bad stories about people getting stators and regulators from e bay and having trouble with them. When I had stator issues, even the local kawi shop said Ricks motorsports had the best ones. I bought one from them and haven't had problems since. Glad to hear you have it running though.
It all makes sense now because in the short time I’ve owned the bike I’ve had every possible bulb burn out and I suspect this has been a problem for a while. I’m going to load test the battery tomorrow and probably look to replace it as I’m sure it’s taken a beating.
