1 - 12 of 12 Posts
This may be the original battery. On my way to work this morning and I noticed the clock had reset. I usually have the display set to the trip odometer, so it was strange to see the time on it at all. The time was wrong and must have reset to 12:00 sometime while I was riding. Pretty sure it was normal when I left the house. I probably had turned it off and started it back up while in traffic as it was exceptionally bad today with last night's storms. The trip odometer had also reset. I should probably get the battery tested and I am guessing it would be just like getting any other battery checked. Any recommendations for OEM or aftermarket battery replacement?
Sent from my SM-N950U using Tapatalk
Like oil, everybody will have a favorite or opinion so: I've bought OEM batteries, over priced brand name batteries, and discount Walmart batteries. The've all performed about the same. I bring them in the house and put them on a tender over the winter. I use the tender if I'm not riding for a week or more and I get 4-5 yrs.
I use Yusa YTX12-BS. Like Steve said everyone has an opinion, I just buy a nice highly rated battery and make sure that it is taken care of properly.
I need to stop to see if Autozone or someone can check the battery for now.
If
If you suspect the battery may be the original it's not even worth a trip to test it, IMO.
Confirm the charging voltage on the bike is OK and, if so, just get a new battery.
I would like to get it tested to see what they say. I DO NOT want to find myself stranded.
That's my point, exactly; to not be stranded.
If it is the original battery you are already on borrowed time for battery life even if, by chance, it would test OK today. This is one of the rare occasions when I suggest to replace a part regardless of testing.
Had the same symptoms of failing batteries as JCC, but the clock/odo reset situation occurred when cranking to start the engine. Starter draws enough power to cause the reset. Have generally bought replacement batteries via the internet - the one which lasted the longest was an unbranded Chinese-made battery which lasted 5 years. Current battery is a Chrome bought via eBay - cost $25 with an eBay $10 coupon. Still good so far after two years.
Discussion Starter #12
Thank you. It very well may have reset after a restart. I was in some traffic and did kill the engine a few times in the commute.
Jeremy
1 - 12 of 12 Posts
