1 - 3 of 3 Posts
The first issue with my bike has surfaced. When I turn the key to the “ON” position, the instrument cluster lights do not come on. Nor do the running lights.
If I push the key into the cylinder, the cylinder depresses and the lights on the cluster and the running lights light up.
My conclusion is that I need to buy a new ignition assembly. My hope is that there is a less costly fix.
The part number (if I have researched this correctly) is 27005-1209 and it’s about $143. It appears to be an easy fix but I wanted to avoid needing three keys for the bike... AND I’m trying to be economical.
Any help or suggestions regarding this problem would be greatly appreciated.
I have posted a short video of the problem here:
https://youtu.be/xlmLgpWl7mY
Discussion Starter #2
Solution to Ignition Switch Problem
After disassembling and cleaning the switch, the problem remained.
I ended up ordering a new assembly from Treasure Coast Honda/Kawasaki and they knocked a couple of bucks off the price. It totaled $138.
Someone with more mechanical competence than myself might have likely fixed it. But at least the bike is up and running again.
1 - 3 of 3 Posts
