Hand Deflectors - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 11-28-2013, 03:27 PM Thread Starter
Hand Deflectors
I went to a local shop for hand deflectors and the only ones they had were fitted for sport bikes. Anyone have a suggestion for good hand deflectors less than $40?
I have a 500 vulcan/no windshield
SantyClause is offline
post #2 of 6 (permalink) Old 11-29-2013, 07:58 PM
A quick ebay search for "cycle hand deflector" returned a lot of entries (most appeared to be the same product) for around $80. May be able to find something used in your range.
2006 Vulcan 500 LTD
2013 Suzuki V-Strom 650 ABS Adventure
Gary W. is offline
post #3 of 6 (permalink) Old 11-30-2013, 06:22 AM
Ghost's Avatar
Google home made wind deflectors. They are pretty easy to make and will only cost maybe $20 in material and some time. I have all the materials for mine. Just haven't had the time time to make them. Good luck.
2012 Nomad 1700
Cobra Luggage Rack
Airlite Crash Bar Chaps
Kuryakyn Offset Highway Pegs
Vulcan Emblem on Passenger Back Rest
Fire and Steel Light Bar
Signal Dynamics Headlight Modulator
Wolo Bad Boy Horn
Kuryakyn Power Point
Back Off XP Brake Light Modulator
08 900 Custom - Traded in!
Ghost is offline
post #4 of 6 (permalink) Old 11-30-2013, 01:43 PM
JS60's Avatar
http://www.gadgetjq.com/hand_wind_deflect.htm
This link is from Gadgets Fixit page.
Try to find a laminate flooring blade for your jigsaw - they are taper ground and gives less chance of welding the plexi back together behind the cut.
Use a very sharp drill bit with some wood backing it up, so it wont splinter the backside of the holes in the plexi.
A good file and a sanding block will let you finish up the edges nicely.
Good Luck!
JS60 is offline
post #5 of 6 (permalink) Old 11-30-2013, 03:39 PM
BOTM Winner
August 2016
keymankirk's Avatar
Year/Make/Model: 2013 Voyager
Displacement/CC's: 1700 cc
Color: Blue / silver
hand deflector
After you sand the edges of the plexi run a propane torch on the edge and you will get a factory like finish. I does not take much heat you will see the edge go from dull to clear .
keymankirk is offline
post #6 of 6 (permalink) Old 11-30-2013, 04:30 PM
Ghost's Avatar
This thread got me motivated to put mine together. I added a horizontal brace to mine since I ride about 60 miles each day on my commute.
I took it for a short test ride. The results are pretty good. I noticed a lack of wind on my fingers. The wind hit me about 3/4 of the way back on my hand.
I'm looking forward to trying them on cooler days.
2012 Nomad 1700
Cobra Luggage Rack
Wolo Bad Boy Horn
Ghost is offline
Hand deflectors keller123 General Vulcan Talk 30 02-12-2014 07:29 PM
National Cycle Hand Deflectors VulcanJohn Vulcan 900 3 09-21-2013 08:22 AM
National Cycle Hand Deflectors For 1700's Netnorske Vulcan 1700 18 01-29-2013 06:15 PM
Hand Deflectors NMGoose Vulcan 1700 13 12-22-2011 12:59 PM
Hand Deflectors for 2010 Vulcan Voyager TechlordTX General Vulcan Talk 0 09-27-2010 02:22 PM
