GPS Power - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By stessel
  • 1 Post By jajy
post #1 of 5 (permalink) Old 02-15-2018, 05:26 PM Thread Starter
Year/Make/Model: 2010 Kawasaki Vulcan Classic
Color: Black and Blue
GPS Power
Can someone give me advice on getting power to a GPS, NOT coming straight from the battery. When I shut the bike off (2010 Vulcan 1700 Classic,) I want the GPS to power down, not drawing from the battery. I know how to hook a lead up to the battery, but I feel that's not the right way.
Thanks.
Wolffmichael is offline
post #2 of 5 (permalink) Old 02-15-2018, 10:46 PM
stessel's Avatar
Year/Make/Model: 2016 Kawasaki Voyager
Color: MetalicBlackk/Silver
Hey, When I mounted my garmin on my voyager using the mount that attaches in the center of the handlebars and replaces the handlebar mount clamps so it is a permanent mount I removed the front cowling shell and spliced the power wire into accessory plug on the RH side of cowling it turned on and off with the key. If your bike does not have an accessory plug you may want to try and splice into running lights or any thing that turns on and off with the key. A gps does not draw that much power so what ever you tap into should be fine. If you do decide to splice into the running lights/blinkers make sure you tap into the running light side not the blinker so you have continuous power. Maybe check it with a voltmeter first.
Wolffmichael likes this.
stessel is offline
post #3 of 5 (permalink) Old 02-16-2018, 01:00 AM
Sabre-t's Avatar
Color: Red/Black
You need to find a power wire that is only on when the key is on. Tap into that wire to trip a relay. The power for the GPS will run thru the relay which only allows the current to flow when the trip circuit is powered. Any keyed on power wire will do. You could use the rear running lights, for example. Google "installing an automotive relay". There is a lot of good info, diagrams, etc., available. You can get a relay at any auto store.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #4 of 5 (permalink) Old 02-16-2018, 09:13 AM Thread Starter
Thanks. I appreciate the direction.
post #5 of 5 (permalink) Old 02-26-2018, 03:40 AM
jajy's Avatar
Year/Make/Model: 2016 Vulcan Classic
Displacement/CC's: 900
Color: White/Grey
In my profile I have some pics and very basic notes on how I did an extra switched fuse box that powers my GPS and other items, it might be useful to you
Cheers
Stock 2016 Vulcan 900 Classic
OEM GPS Mount, Windscreen, Lowers and Engine Guards
Chaps for the Engine Guards
TomTom 400, GoPro Hero 5
Sena Bluetooth SMH10R, Sena Bluetooth 10U for Neotec Helmet
Shoei Neotec Flip Face
Scorpion Alarm System SRX-900 (new)
2 sets of Saddle Bags and Brackets
Additional 6 fuse, Fuse Box switched from Accessory port
Full LED Headlight Replacement
Baron Front Pulley
Stock Seat reshaped and a Utopia Backrest
ST2 Turn Signal Cancel Module (new)
jajy is offline
Kawasaki GPS Connection Cable with Other GPS Units Kap Vulcan 1700 5 11-06-2015 10:18 AM
GPS power cord draining battery.... X-Rider Vulcan 900 25 05-14-2011 08:31 AM
power for GPS rebeckstrom General Vulcan Talk 11 05-07-2011 07:30 AM
Aux power for GPS Amerimutt Vulcan 900 1 03-21-2011 10:32 PM
1700 Voyager (GPS Power) t-bear Vulcan 1700 16 03-18-2011 09:18 AM
