Converting front turn signals to running LED white lights? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 24 (permalink) Old 05-04-2017, 11:26 PM Thread Starter
Year/Make/Model: 2012 Kawasaki Vulcan 900 custom
Displacement/CC's: 903
Color: Purplish pearl/Black
Hi everyone, I currently am running an LED front headlight (always on high) and I want to add more lighting for visibility. I'm steering away from a light bar since I like the look of a single front headlight on the vulcan 900 custom and not sure of modulators yet since it won't work on LED. I saw this product from a local light shop that converts the front stock turning signals into running white LED lights that turn yellow when the turn signal is activated.
What are everyone's thought? Have you seen something like this before? Do you think it will work and add more lighting and viaibility or maybe even replace a light bar?
https://chromeglow.com/products/bulb...ignal-inserts/
JonF is offline
post #2 of 24 (permalink) Old 05-05-2017, 07:17 AM
Year/Make/Model: 2013 Kawasaki Vulcan Nomad 1700
Color: Titanium and Black
It looks like a great idea. However, we need to find out if it will work to replace the Kawasaki turn signal. It says it fits a Harley style turn signal. If it will work, I'll buy one.
Ultimate Seat with Driver Backrest
Ivan's ECU flash 2
Freedom performance Slip on mufflers
Luverne Kawasaki Lowering Kit
Batwing fairing
Darkside 205/60/16 with Endeavor reversed trike
Huddleston is offline
post #3 of 24 (permalink) Old 05-05-2017, 07:46 AM Thread Starter
Here's the link thay states it fits the kawasaki vulcan. However it looks like this model won't flash in different colors, it will stay either white or amber. Do you think this will work?
http://chromeglow.com/products/turn-...from-radiantz/
JonF is offline
post #4 of 24 (permalink) Old 05-05-2017, 08:01 AM
Lumber-jack's Avatar
Year/Make/Model: 2009 Voyager 1700
SuperBrightLED has orange/white switchback signal lights that I have used in several bikes. You need a clear lens of course to get both colours to function. FYI It is recommended to get bulb same colour as lens to maximize output.
_________________________________
"If you want to feel smart, get stupid freinds..."
Lumber-jack is offline
post #5 of 24 (permalink) Old 05-05-2017, 08:56 AM
Coyote Krause's Avatar
Year/Make/Model: 2016 Kawasaki Vulcan 900 Classic
Displacement/CC's: 900
Color: Imperial Red and Graphite Grey
Always on High??? With LED's??? That's a sure way to piss off Cagers and fellow riders...
Kick the Tires!!! Light the Fires!!!
Coyote Krause is offline
post #6 of 24 (permalink) Old 05-05-2017, 09:41 AM
Bpalmer's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan Classic
Color: Blue
If you mean "High Beam", it might even be illegal.
Sometimes I get the feeling the whole world is against me, but deep down I know that's not true.
Some smaller countries are neutral. - Robert Orben
Bpalmer is offline
post #7 of 24 (permalink) Old 05-05-2017, 09:51 AM
I just called chrome glow and was told that it would not fit the Kawasaki Nomad 1700. The reason given is that the front lens will not come off. I looked at mine and I think they are correct because the bulb goes in from the back. Looks like you would need to replace the light housing with one that is compatible with HD signals. I took the screw loose that holds the light housing to the bar, but could not find how to remove the housing from the bar. Does anyone know how that works? I couldn't find it in the service manual.
I like the idea because after adding a batwing fairing to my Nomad, there is no room for separate driving lights.
Ivan's ECU flash 2
Batwing fairing
post #8 of 24 (permalink) Old 05-05-2017, 09:57 AM Thread Starter
Yes I meant high beam. Prev owner told me that he was always on high and never had any issues. Its a 200 lumens if that would be overwhelming led brightness? I live in south florida, the highest motorcycle fatalities in the country. I would take the risk of being overseen than getting hit. On daylight it's not that blinding, which is mostly when I plan on riding.
JonF is offline
post #9 of 24 (permalink) Old 05-05-2017, 09:59 AM Thread Starter
Correction 2300 lumens
JonF is offline
post #10 of 24 (permalink) Old 05-05-2017, 11:27 AM
Its against the law in Florida. (Florida State Statute 316.238) carries a hefty $179.00 fine as a “Moving Infraction”.
Retrofit LED Lamps for Existing Turn Signals- Turn Signals 101 rangemaster728 Vulcan 650 S 32 02-03-2018 04:12 PM
Turn rear turn signals to running lights???? gibi Vulcan 900 18 05-19-2015 03:22 PM
Converting Cobra Driving lights to LED bulbs mtpocketsad Vulcan 900 0 05-24-2013 09:00 PM
Rear Turn Signals / Running Lights? Kankujoe Vulcan 500 20 08-17-2012 06:37 AM
Converting to LED signals ? XCR600 Vulcan 800 10 08-30-2011 01:18 PM
