Last week I had a stuck starter relay, killed the battery. Today I tapped the relay and got it to function properly again and gave the bike a jump.
It’s idles strong for a few minutes but after, starts hesitating and eventually dies completely.
Runs strong with 12v coming from jumper cables so I’m assuming it’s a stator issue.
Battery voltage rose by 1 or 2 volts each time I ran the bike (so there’s at least enough current generated to charge the battery) but not enough to run for more than a minute or so without 12v assist
Any thoughts about potential voltage regulator or coil issues that can disguise themselves as a stator issue?
