T-tap connectors...can they be trusted? - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #11 of 13 (permalink) Old 04-15-2019, 11:28 AM
whoaru99's Avatar
Originally Posted by RastaPasta View Post
I did end up tossing the supplied connectors in the trash and soldered/shrikwrapped instead. It was my first solder job, so it's a bit ugly but it's solid (bigger da gob the better da job!).
The key is whether or not the solder wetted and flowed into the joint. Without seeing the joints of topic it's hard to say for sure but I've seen some pretty impressive solder gobs that were not sound electrically-speaking (aka cold joints).
Sabre-t likes this.
whoaru99 is online now
post #12 of 13 (permalink) Old 04-15-2019, 12:30 PM
Sabre-t's Avatar
Color: Red/Black
Yeah, the "if a little is good, a lot must be better" logic can produce some really bad results.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #13 of 13 (permalink) Old 04-16-2019, 09:40 AM
Hathaway's Avatar
Year/Make/Model: 2015 VN1700B
Color: GRY/BLK
You can actually see the permeation of the solder, through the strands of the wire. A fully heated iron(or gun), and you can melt the solder through the splice. If you saw something like this when you were soldering, you're probably okay.
If you are worried about the result, you can always redo it. Resin core electrical solder (small gauge) would work well for this. Nice thing about soldering - "Practice makes Perfect"!
Hathaway is offline
they dont talk like this down under,, do they? Poncho Villa The Lounge (Off Topic) 7 12-17-2017 03:31 PM
because they CAN, they believe they MUST Poncho Villa The Lounge (Off Topic) 21 09-13-2012 03:52 PM
And they wonder why they cant sell bikes ! whiting57 Vulcan 900 28 01-12-2011 06:01 PM
fuel tap question pamelove Vulcan 800 2 05-12-2009 07:26 AM
