VN900 Diode mod: Your all LED turn/Indicator solution - Page 3 - Kawasaki Vulcan Forum : Vulcan Forums
 4Likes
post #21 of 29 (permalink) Old 05-22-2018, 09:03 PM
Just wanted to say that I did this mod after adding led turn signals.
I added the four turn signals (two forward, two aft) and got the four-way hazard light blink. Nice to have since the Vulcan does not have flashers. But I could not leave her that way. So I did the mod as described (thanks for the pics) and it worked like a charm.
While I was in there, I left the original t/s on the front but changed the orange lens to a clear one and added a led bulb. I also removed the t/s wire from it (I used that on the led t/s) making it a light bar sort of. With the led t/s above them. Check pic.
Thanks for the mod post, I'm sure it has helped a lot of riders.
darkkon likes this.
Netrick is offline
post #22 of 29 (permalink) Old 05-24-2018, 04:45 AM
Diode Kit
Just installed the diode kit and it worked perfectly! Thanks for the detailed thread!
SNorris is offline
post #23 of 29 (permalink) Old 06-15-2018, 08:35 AM
Year/Make/Model: VN900 CLASSIC 2007
Displacement/CC's: 900
Color: RED
Thanks for the guide, followed it and all went great!
Now waiting for the LED flasher to arrive to install it along with the rear bulbs which I have converted to running+turn.
I intend to keep the front bulbs not LED as they are not on all the time so do not draw current when not used.
darkkon is offline
post #24 of 29 (permalink) Old 07-16-2018, 01:54 PM
Joe Smith's Avatar
Year/Make/Model: 01 kawasaki vulcan vn1500e-4
Displacement/CC's: 1470
Color: black
Will this work on 01 1500 classic? It is equipped with running and turn. Also did you replace the thermal flasher with electric? Only problem I see that I will have is no matter how hard I try my soderinng sucks. Lol
Joe Smith is offline
post #25 of 29 (permalink) Old 07-18-2018, 02:50 AM
Joe Smith's Avatar
Color: black
No it will not if anyone was curious as well. Lol completely different wiring just two wires coming from indicator light green and yellow. I just cut them and also swapped running and signal wires as well. Everything works great also I guess due to the lack of electronic flasher relay the back turn signals are now running lights as well.
post #26 of 29 (permalink) Old 05-26-2019, 01:16 PM
denali1234's Avatar
Year/Make/Model: 2017/Kawasaki/Classic LT
Color: two tone black/metallic grey
Putting LED's on the bike is not as easy as screwing bulbs in:
https://www.vulcanforums.com/forums/...-solution.html
2017 Vulcan 900 Classic
Mustang seat with back rest
OEM Engine guards
OEM Radiator protector
Airlite Engine Guard chaps
Black Kuryakyn Kinetic Grips with Throttle Boss
Memphis Shades Batwing
Memphis Shades Lowers
2 inch risers by Chucksters Customs
Cobra Luggage Rack
Classic LT Kawasaki saddlebags
Mustang Tank Bib
Show Chrome Front Fender Rail
Gone but not forgotten:
2013 Honda Shadow Aero 750
1998 Yamaha Virago 1100
1985 Kawasaki 440
1984 Honda 250 Custom
denali1234 is offline
post #27 of 29 (permalink) Old 06-03-2019, 07:36 AM
How do I get the speedo face off? The 2 screws on the face of it? I took apart to that point and got stuck.
Thanks.
Normshot is offline
post #28 of 29 (permalink) Old 08-09-2019, 02:04 PM
Year/Make/Model: 2009 Kawi Vulcan 900 Custom
In case anyone irreparably screws up the wiring you can buy a new "Lamp assembly" board which comes with the multi-wire ribbon cable that you have to cut for this mod. It's part # 23016-1186 and spans many years of the 900, but you should still check to ensure proper part. It's roughly $65. It's easy to accidentally pull a wire from its contact with not much force. Better to release the contact from the header via 2Lucky's post in Post 10.
Splat (yes, it's my nickname!)
Splat is offline
post #29 of 29 (permalink) Old 08-13-2019, 08:06 AM
Rockvaiv's Avatar
Year/Make/Model: 2008/Kawasaki/VN 900 Classic LT
Displacement/CC's: 903
Red face
Hi! What type of diods did you use/should I use? How much W and V... Zener or Schottky...
Good day to you!
Rockvaiv is offline
VN900 Gear Indicator Mod 2lucky Wrench Heads 22 04-22-2018 08:18 PM
R&G Racing Fender Eliminator with Kuryakyn LED Torpedo Turn Signal Indicator Lights rdpgreen Vulcan 650 S 5 07-28-2017 08:50 PM
Diode Kit for LED turn signals Bill Braske Vulcan 2000 2 04-27-2013 07:23 AM
LED signal diode problem.... Brandonhill81 Vulcan 900 0 07-03-2010 05:40 PM
LED turn signal indicator pickandpray Vulcan 500 4 04-10-2010 09:06 PM
