Piston hit spark plug - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #1 of 14 (permalink) Old 09-02-2019, 06:49 PM Thread Starter
Year/Make/Model: 2002/Vulcan/Classic
Displacement/CC's: 800
Color: Purple
New 02 Vulcan 800 owner. Picked up Friday and was putting some miles on it Saturday. Bike has 28k miles. At around 170 miles of me on it and cruising at 85 mph it lost power. Got it home. Pulled plugs and this is what I see.
Anyone have a clue what would cause this? I’ll have to assume the motor it done. I am tempted to put new plugs in and see what happens.
Wikid1 is offline
post #2 of 14 (permalink) Old 09-02-2019, 09:10 PM
Vulcan guy's Avatar
Year/Make/Model: 2001 Vulcan VN1500, 2005 Vulcan VN1500
Displacement/CC's: 1500
Color: Green, Blue
Looks like he may have installed wrong plugs before he sold it. At this point you have nothing to lose.. Try it!
Vulcan guy is offline
post #3 of 14 (permalink) Old 09-03-2019, 01:17 AM
Berw's Avatar
Year/Make/Model: 2007 900
Displacement/CC's: 903
Color: Blus
I used to race a Lotus 900 series engine, these are well known for pistons touching plugs due to rod stretch at high revs, It is not unknown for there to be no damage to the engine, the plug can 'compress' a little at the gap, so try new plugs, reason is either rod stretch (so piston is to high) or plug to low, this can be wrong/long plug or i've seen some one remove the compression washer/ring of the plug.
Berw is offline
post #4 of 14 (permalink) Old 09-03-2019, 07:12 AM
DaPreacha's Avatar
Year/Make/Model: 2012 Kawasaki Nomad
Color: Red/silver
You probably want to run a magnet around the top of the piston to make sure there are no bits of plug left before installing new ones.
DaPreacha is offline
post #5 of 14 (permalink) Old 09-03-2019, 07:13 AM Thread Starter
Color: Purple
Turned out they match what’s in the owners manual. I put new in and it still didn’t start. I’m getting fuel and spark. Sprayed starting fluid. I’m beginning to think the piston has a hole or it’s missing a valve. I can’t test compression with how deep the cylinder is.
I bet you’re right. I doubt this little 800 likes to rev high for long periods. It had the correct plugs and still had the compression washer on the old ones.
Frustrating. Thought I had bought a good little runner. I think I’ll need to figure something it part out or engine off eBay.
Wikid1 is offline
post #6 of 14 (permalink) Old 09-03-2019, 07:26 AM
Year/Make/Model: 2006 Vulcan 900 Classic, 1991 Honda 750 NightHawk
Displacement/CC's: 900, 750
Color: Red and Black
“cruising at 85 mph”
Vulcan 800 - “cruising at 85 mph”
I have the Vulcan 900 I am not able to cruise at 85 mph
Seems like a new owner fail!!!
Shinko 230 Tour Master Tires Rear tire 180/70-15 Front tire 130/90-16
Biebs is offline
post #7 of 14 (permalink) Old 09-03-2019, 07:44 AM Thread Starter
Color: Purple
I wanted to try that but couldn’t locate my magnet. It still didn’t start when tried. I feel like it’s lost compression. It’s just weird since there’s no funny sounds. It turns over just as normal.
Seems like a new owner fail!!![IMG class=inlineimg]/forums/images/VulcanForums_2015/smilies/tango_face_surprise.png[/IMG]
Your 900 isn’t able to get to 85? In this part of Texas you’d be run over!
This 800 wouldn’t go much over. That was about it.
Wikid1 is offline
post #8 of 14 (permalink) Old 09-03-2019, 09:51 AM
My 900 will do 85 MPH - but that is not cruising speed or comfortable.
Biebs is offline
post #9 of 14 (permalink) Old 09-03-2019, 10:38 AM
More likely it has dropped a valve. Not unheard of on 800's that have had valve lash checks ignored.
SpinDog likes this.
sfair is offline
post #10 of 14 (permalink) Old 09-03-2019, 10:52 AM Thread Starter
Color: Purple
Do you think it would drop both at same time? That's what has me puzzled. I hate to start tearing down the engine.
I'm not sure it it'd be cheaper to fix the current motor, get one off ebay, or dump is as a parts bike... I bought it so my little brother could ride Twisted Sisters with me and my Dad 9/19. So that sounds like I'll either need to buy another bike or he's not coming.
Wikid1 is offline
