Starter Solenoid - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By vulcandoc
post #1 of 7 (permalink) Old 07-08-2019, 10:16 AM Thread Starter
Year/Make/Model: 1996 Kawasaki Vulcan
Displacement/CC's: 800
Color: Black
Starter Solenoid
I have a 96 VN800b. my starter solenoid sometimes makes a buzzing like it is not holding contact. Obviously when this happens, it will not crank. But I can hit the starter button again and it doesn't do it.
Does this mean my solenoid is going out? I have already replaced the battery with an AGM type. I have cleaned all the connections and cut out and hardwired the melted white 3-wire connector from the stator.
Daddy.Diesel is offline
post #2 of 7 (permalink) Old 07-10-2019, 09:12 AM Thread Starter
Color: Black
Just wanted to say thanks for help guys! This post got 42 views and not one piece of advice.
post #3 of 7 (permalink) Old 07-10-2019, 09:45 AM
Vulcan guy's Avatar
Year/Make/Model: 2001 Vulcan VN1500, 2005 Vulcan VN1500
Displacement/CC's: 1500
Color: Green, Blue
Guess nobody has a 1996 VN800b with similar starter problem.
Vulcan guy is online now
post #4 of 7 (permalink) Old 07-10-2019, 09:47 AM Thread Starter
Color: Black
I guess not but I hear alot of the solenoids are the same
post #5 of 7 (permalink) Old 07-10-2019, 10:15 AM
Color: Black / grey
A solenoid will either work or it wont.
Yes it could mean its breaking down, but since it doesnt do it every time dont be to concerned.
For your sanity you could replace it, but if they are a bit pricey and the next one does the same thing.....
vulcandoc is offline
post #6 of 7 (permalink) Old 07-10-2019, 10:22 AM Thread Starter
Color: Black
could it be the relay in the distribution box getting weak?
If I'm correct, when you push the start button the power comes from the distribution box to close the solenoid so the starter engages?
post #7 of 7 (permalink) Old 07-10-2019, 02:55 PM
Color: Black / grey
Again a solenoid works or doesn't, and they CAN make noise but that doesn't mean its going bad.
Have you checked the battery voltage when you hit the start button?
It should not fall to far from battery voltage level BEFORE the start button was pushed.
Meaning, and these numbers are just an example, if battery is at 13 volts, when you hit start it should not drop to under 11 volts.
jdocster likes this.
