Where do I put the hose? - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By DKC
post #1 of 9 (permalink) Old 07-07-2019, 07:04 PM Thread Starter
Michael Martin's Avatar
The small breather hose that is about 5” wasn’t connected when I took off the plastic housing in front of the carb.( stayed on the housing) I don’t see where to stick it in the manual and there are no videos that specify said hose. Manual says it’s a breather hose and I’m assuming something needs it to breath. Hose itself and manual both show 2 clamps on both ends so I’m guessing it’s meant to be connected. Much appreciated if I could some help. Thx buds
Last edited by Michael Martin; 07-07-2019 at 08:03 PM. Reason: I found a picture to go with my post
Michael Martin is offline
post #2 of 9 (permalink) Old 07-07-2019, 08:12 PM
DKC
Year/Make/Model: 2008 en500c
Displacement/CC's: 500
Color: Black
On the lower portion of the air cleaner assembly, there should be a small port for that hose to connect to.
Here is a diagram showing an exploded view.
Hope this helps!
Edit:
The image didn't turn out as well as I had hoped, so here's a link to the page:
https://www.partzilla.com/catalog/ka...b3/air-cleaner
Vulcan guy likes this.
DKC is online now
post #3 of 9 (permalink) Old 07-07-2019, 08:31 PM Thread Starter
I have the hose hooked up to the bottom port on the plastic. Does it stay unconnected? I saw that it hooks up behind the carb but I’m not seeing it on my bike.
post #4 of 9 (permalink) Old 07-07-2019, 08:31 PM Thread Starter
Thx for taking time to help me out👍
post #5 of 9 (permalink) Old 07-13-2019, 05:10 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
the hose hooks up behind the carb, you mean at the top of the carb nearest the air intake? that's the petcock vacuum hose
btom is offline
post #6 of 9 (permalink) Old 07-14-2019, 09:02 AM Thread Starter
No it’s the short hose that hooks up on engine. I had to take the carb off to find where to hook it up at. I’m assuming cause it’s the only port without a hose connected.
post #7 of 9 (permalink) Old 07-14-2019, 09:08 AM Thread Starter
The site is not letting me upload any pictures but it’s right under the seat. It is like it flows back into engine from the air intake. Sure wish I could show the pick of where I found it.
Last edited by Michael Martin; 07-14-2019 at 10:19 AM. Reason: This is where the hose goes👍
post #8 of 9 (permalink) Old 07-15-2019, 05:02 PM
btom's Avatar
what hose is that?
btom is offline
post #9 of 9 (permalink) Old 07-15-2019, 05:03 PM
btom's Avatar
what goes thru that hose, air or liquid?
btom is offline
