Turn Signal with Emergency Flashers??? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 05-24-2019, 09:53 AM Thread Starter
Year/Make/Model: 2002 VN800B Classic
I have a 2002 VN800 Classic. The Turn signal does not have an emergency flasher option?
Does anyone know of an aftermarket kit or new assembly that would have that?
Meatluft is offline
post #2 of 7 (permalink) Old 05-26-2019, 11:46 AM
DKC
Year/Make/Model: 2008 en500c
Displacement/CC's: 500
Color: Black
I'm not sure of any factory optioned system that has emergency flashers for a Vulcan. However, if you're good with wiring work, and don't mind getting a little creative, I have a work around that I'm gathering parts for to swap onto my own 500...
Several HD models use a separate turn signal switch for each side. A basic on/off switch on each side of the handlebar controls. My 500 has 1" bars, same as most of these HD models, and I'm pretty sure your 800 will too. My thought is to change the electronic portions of my controls for these HD components. It'll take some getting used to at first, right turn signal on the right side control, but then if you need emergency flashers, you simply turn both sides on at once.
My idea is still in the drawing board stages to be honest. I'm on a super tight budget, so parts gathering is slow... Mainly hoping someone comes into the shop looking to chrome out their controls and I can keep their factory black pieces and knock a little off the labor...
The wiring wouldn't be too terribly hard to work up, if you have a good mindset for it. You would have to add/change a couple wires from the current configuration.
I'll try to work up a sketch to demonstrate how the wiring is and would need to be done.
DKC is offline
post #3 of 7 (permalink) Old 05-30-2019, 03:52 PM
Year/Make/Model: 2005 Drifter, 2017 Vaquero, 1978 FXE, 1988 XLH
Displacement/CC's: 800, 1700, 1573, 883
Color: Grey, Red, Plum Crazy Purple, Red
I saw this when you posted it, but forgot my password.
I've got the service manual, and the schematics show that there is wiring in place for flashers.
I have not tried to hook them up though.
It looks like the Canadien version of the bike has them from the get-go.
I'll try to get the schematic scanned, but if you have the manual, look at the diagram for the handlebars.
Teledog74 is offline
post #4 of 7 (permalink) Old 06-27-2019, 07:06 PM Thread Starter
Nice. Great suggestions.
Meatluft is offline
post #5 of 7 (permalink) Old 06-27-2019, 10:23 PM
Berw's Avatar
Year/Make/Model: 2007 900
Displacement/CC's: 903
Color: Blus
I'm in the process of doing this, made up a kit, handlebar switch and 2 pin flasher from Ali express 20Us$ delivered for both. Checked them out good quality I've used the same switch before to wire in Day light Running Lights, will fit next week, basic wiring is a permanent battery live through switch to flasher then split to two wires to feed the left and right turn light, all very easy, the L terminal on the flasher ls Load so the wire goes from there to the lights. I'm planning to mount via a relay so any wire drawing the current to the lights is kept around the center line of the bike, and I'm only running the switch wire to the handle bar, I then intend to use a reverse relay feed from the existing turn switch to kill the emergency light feed if I turn the flasher on.
Hardest job will be getting the tank off to run the wires neatly up the back bone of the bike.
Berw is offline
post #6 of 7 (permalink) Old 07-26-2019, 02:28 PM Thread Starter
I was thinking about doing something along these lines Berw. Your suggestion is great. Thanks everyone for the feedback.
Meatluft is offline
post #7 of 7 (permalink) Old 07-26-2019, 09:18 PM
Berw's Avatar
Color: Blus
My installation is delayed due to work. as I said above basic installation is simple live feed to a switch on handle bars, through a two pin flasher, split the wire and connect to the left and right indicators between the existing switch and the bulb.
Problem I see is that when you turn on this switch the earth side of the existing switch is seeing power, no issue providing you donyt turn the indicators while operating the Hazard.
There are a few ways to stop this either using relays or one way diodes.
Berw is offline
Turn signal issue spaych Vulcan 650 S 4 09-19-2015 05:49 AM
LED tail light and turn signal conversion with 2->3 wire mod zaku Vulcan 1500 12 09-17-2015 12:55 PM
Turn Signal flashes fast Shark88 Vulcan 900 3 09-01-2015 10:09 AM
Turn signal issue mears Vulcan 800 7 11-02-2013 08:39 PM
Lighting Projects Continued--Turn Signal Conversion=>Running/Brake Lights 3degree Vulcan 1500 0 06-07-2010 02:30 PM
