Carb issue, off idle bogging - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 04-08-2019, 05:28 PM Thread Starter
RideRed0331's Avatar
I have a 1998 Vulcan 800 Classic. I bought the bike after it had been sitting for a while. I cleaned the carb really well, blew air through everything, and installed new jets, needle, float needle, and gaskets. When the bike is running and I just stab the throttle from an idle, the bike will die. However, if I slowly twist the throttle to bring the RPMs up by about 500, I can stab the throttle and the response is instant. Also, when I pull the choke lever out, the bike will die on me. Another thing I noticed is that the accelerator pump doesn’t squirt fuel out when I twist the throttle, but it seemed to squirt fine when the carb was off the bike for a rebuild.
My current jetting:
50 pilot
170 main
Stock needle w/ 2 shims
A/F screw doesn’t seem to change anything but is set at 2 turns out
RideRed0331 is offline
post #2 of 2 (permalink) Old 05-26-2019, 10:24 AM
TroyT75's Avatar
I just rejetted mine. I'm running: 145 main jet, 50 pilot jet and no shims on my main needle.
I bought my kit from 6 sigma. They custom make it for you and your bike, also to what modifications you've done to your bike.
TroyT75 is offline
Requires advance idle knob for cold startups Elitemuppet Vulcan 1500 0 09-22-2018 01:24 PM
Hanging idle and popping from carburetor starlightfury Vulcan 500 16 06-27-2016 01:25 PM
Carb issue (maybe common?) Argulace Vulcan 800 1 04-10-2016 07:46 PM
96 1500D Idle Issue 00gt1 Vulcan 1500 3 03-27-2016 06:27 PM
carb farts when i lower my idle papayadialog Vulcan 800 12 10-12-2015 09:47 PM
