Clutch and/or Gear issue? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 12 (permalink) Old 02-01-2019, 11:21 AM Thread Starter
Arzante's Avatar
So I went for a 240 round trip a couple of weeks ago and on my way back I jumped down into 4th to get out of the way of a car and noticed my bike had no power until I dropped the throttle a bit then the clutch finally caught. I figure worn friction plates. Even more curious though, for the second time (the first time I thought it was false neutral) I was cruising about 75 then my bike jumped out of gear for about 1 second the popped back in. It hailed one more time then not again. Any ideas if that would be clutch related or gear related?
Arzante is offline
post #2 of 12 (permalink) Old 02-03-2019, 09:20 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
clutch plates are not the problem, it's the clutch cable adjustment, there's a nice harley-davidson clutch cable adjustment method on youtube that could be helpful for you, there's a right and wrong way of doing this
btom is offline
post #3 of 12 (permalink) Old 02-03-2019, 10:37 AM
1. What year is the bike?
2. How many miles?
3. What gear did it jump out of?
sfair is offline
post #4 of 12 (permalink) Old 02-03-2019, 08:30 PM Thread Starter
Arzante's Avatar
02 800b . Jumped out of gear the popped back in
Arzante is offline
post #5 of 12 (permalink) Old 02-03-2019, 08:32 PM Thread Starter
Arzante's Avatar
37k miles. Nee clutch cable. Put 3k miles in no problems after bar swap. 1/8 in freeplay on clutch handle
Arzante is offline
post #6 of 12 (permalink) Old 02-04-2019, 10:29 AM
What gear?
sfair is offline
post #7 of 12 (permalink) Old 02-04-2019, 10:30 AM
Are you saying no problems now?
What is a nee clutch cable?
sfair is offline
post #8 of 12 (permalink) Old 02-04-2019, 10:48 AM Thread Starter
Arzante's Avatar
Sorry. Fat fingered. New* clutch cable. And 5th gear. Id be cruising and the transmission would lightly pop the engine would rev the tranny would pop one more time and re-engage
Arzante is offline
post #9 of 12 (permalink) Old 02-04-2019, 11:29 AM
Ok, just wanted to be clear on the problem. A clutch or cable will not cause it to jump out of gear.
A couple more questions:
1. How long have you owned?
2. Any other issues, no matter how unrelated to this?
3. You changed the cable because of a bar swap?
4. Would it jump out under heavy load or light throttle?
sfair is offline
post #10 of 12 (permalink) Old 02-04-2019, 11:35 AM Thread Starter
Arzante's Avatar
So I was cruising at about 70-75 for a long while so I can't say heavy load. I've had 4th slip while trying to down shift from 5th to pass a car. I've owned for 9 months I did a 433mi ride after bar swap 5 months ago and had no issues. And yes. I swapped stock cable to put 12" mini apes on.
Arzante is offline
Clutch issue daremoe63 Vulcan 1500 12 07-10-2017 04:40 PM
92 Vulcan 1500 Clutch Won't Disengage After New Spring Install cp___32 Vulcan 1500 10 05-27-2016 11:36 AM
Clutch slippage Romans5.8 Vulcan 900 11 08-05-2015 07:22 PM
92 Vulcan 88 clutch saftey issue John500 Vulcan 1500 7 11-18-2013 11:23 AM
Clutch issue Aleco Vulcan 900 6 09-10-2013 10:19 AM
