99 VN800B Coolant Leak - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 01-08-2019, 03:21 AM Thread Starter
I bought this bike a few months ago and had to clean the carb to get her running again. The other day I let the bike warm up for about 15 minutes before going on a ride and came out to find coolant on the ground. I usually let it warm up for a bit because it bogs out when I give it throttle before warming up. However, if it warms up first, the throttle operates correctly throughout the entire throttle pull. It hasn't leaked coolant before. After looking around the bike, it looks like the coolant was coming up into the air intake through the engine breather tube from the rear cylinder. I found coolant on the back end of the carb, in the air intake, and pooled up on top of the engine under the air intake. I checked the coolant at the cap, which was full, and tried to check at the coolant reservoir; however, the clear tube to check it is weathered and not clear enough to see the level. I have yet to add coolant, and I am going to do an oil change to check the clarity and see if maybe I have a blown head gasket. It could be as simple as it overheated enough to boil over and all I need is some more coolant or it could be a bigger issue. I also have to say the coolant that leaked out looked just fine. It was bright green and didn't seem to be burnt or have any oil in it. It didn't look like it was discolored. Please let me know if you have had a similar issue. Thanks and happy riding.
Santiago94 is offline
post #2 of 3 (permalink) Old 01-31-2019, 08:44 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
how did you make you?
that coolant reservoir check level tube on my bike is also weathered and not clear, so what I did was syphon out all the fluid then measure out one-half litre to put back in
btom is offline
post #3 of 3 (permalink) Old 03-05-2019, 04:47 AM
I have a simular issue with coolant coming into the air breather. There is no sign of coolant coming from the pump "leak" hole however. It appears that coolant is in the engine as well. The bike was just rebuilt from installing 2nd gear. Any idea if this could be a water pump or any other likely issue? An help would help greatly !!
Waltonts is offline
Gas leak in '99 Vulcan TLuurts Engine Work 2 06-30-2014 08:01 AM
No coolant out the coolant drain plug?!?! WildMan Vulcan 800 21 12-16-2013 11:35 AM
New guy in O-H-I-O '99 VN800B CycloneRider New Member Introductions 5 09-14-2010 06:25 PM
99 Nomad 1500 fuel leak from carb hiskid Vulcan 1500 6 07-27-2010 09:57 PM
Coolant Leak at 7800 miles? fhukenmoven Vulcan 500 0 04-20-2009 07:17 PM
