Question regarding heated gloves and vest - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 01-05-2019, 11:42 AM Thread Starter
Hi guys and gals,
My question is can I hook up battery leads for heated gloves and a vest on my 800?
I replaced the front and rear directionals with Kuryakin lights. That's all the electronics
that I replaced. Otherwise the bike is stock. Any info and or recommendations on which brand to get and if I'm better off with a battery set.
Thanks in advance for your help,
Ed
ejacko is offline
post #2 of 6 (permalink) Old 01-05-2019, 03:41 PM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
you can have heated vest and glove leads connected to battery, but just be aware that when you're at a stop, with headlight and all other lights on, you'll drop down below charging, meaning if you stay at the stop long enough the bettery will drain, so keep your revs up whenever possible so stator can keep up with the heated vest and gloves amp draw, i think total stator can output is 23 amps @ 8000 rpm
btom is offline
post #3 of 6 (permalink) Old 01-05-2019, 09:23 PM
Buskman's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan Classic LT
Displacement/CC's: 900
Color: Red/Black
Originally Posted by ejacko View Post
...and if I'm better off with a battery set.
Ed
Have never installed the equipment needed for heated gear on my bike...so...others who have are more beneficial to you in that department.
As for heated gear, I have been loving these Volt Tatra 7V. LI Battery Heated Gloves I bought last year. I ride in pretty cold temps at highway speeds for moderate distances.
These things...so far...have worked great.
It truly depends on your personal threshold for cold temps while on a bike, though.
At 30*, my hands are what I would call....room temperature. Not overly warm...but not cold either. And that is on setting 3..out of 4.
Looking into the same brand's heated vest...may pull the trigger on one.
HTH, my friend
"...These go to eleven."-Nigel Tufnel, Lead Guitarist, Spinal Tap
"I aim to please...but sometimes I hit the seat."-Buskman, Lifetime Premium Member, VulcanForums.com
Buskman is offline
post #4 of 6 (permalink) Old 01-06-2019, 08:35 AM Thread Starter
Thanks for the quick and extremely informative reply.
ejacko is offline
post #5 of 6 (permalink) Old 01-06-2019, 08:36 AM Thread Starter
Thanks I have to decide which way to go. Battery or direct
ejacko is offline
post #6 of 6 (permalink) Old 01-06-2019, 09:50 AM
Buskman's Avatar
Color: Red/Black
You're welcome, my friend...
Like many others here...glad to help.
Buskman is offline
Heated grips, heated gloves or both? dennisbernal91z Vulcan 650 S 7 03-07-2018 09:23 AM
Ran with Heated Jacket and Gloves today and did not die motor_psycho Vulcan 650 S 3 03-18-2017 10:54 PM
Venture Heated Jacket Liner and Gloves VulcanJohn Vulcan 900 7 10-10-2013 12:39 PM
