Winter Storage tips - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 10-31-2018, 12:49 PM Thread Starter
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
Winter Storage tips
This guy has good tips on how to store a motorcycle for storage, except where he says to start the bike every couple weeks and let it run for 10 minutes, but I don't do that, I just leave the bike alone and drain the gas from the carb bowl and not start the bike all during storage. because heating up the crankcase then when the crankcase cools down causing hot to cold inside it forms condensation (rust), and I don't cover up the bike because that traps the moisture under the cover, (again rust), let it breath, for longer term storage remove the plugs and spray fogging oil inside the cylinders and turn the crank over a couple times then reinstall the plugs, if you leave the plugs uninstalled you might forget to tighten them again at end of storage, and yes use a 1.25amp battery tender but it leaving the bike outside then do remove the battery and yes lube your cables and chain, check out his video tips. And for gas tank I put in seafoam and fill it up expelling all the air.
btom is online now
post #2 of 3 (permalink) Old 10-31-2018, 03:04 PM
That guy's videos are hilarious! He's a bit nuts about a few things, but does have salient points to make.
For me, winter storage is filling the tank, adding fuel stabilizer, lube the chain, putting the bike in its shell (Cycle Shell), hooking up the tender. In spring I'll just pull it out, check the tires, and ride!
I've stored my bike for 8 years this way without issues. Gotta let it breath if the moisture level stays high for a while, or spray some mold/mildew armor in the shell.
-John
2016 Vaquero (mostly stock)
2005 VN800B Bobber (Blue Collar Bobbers kits)
1979 KZ650SR
DraKhen99 is offline
post #3 of 3 (permalink) Old 10-31-2018, 03:16 PM
Color: Black / grey
Then there's over kill.
NUMBER ONE - Check that the coolant can withstand freezing temps. (50/50 mix good to -35°F)
Add seafoam before your last ride so that the seafaom gets into the carbs.
Add more seafoam and fill tank with gas,
remove battery and take inside with a trickle charger,
lube chain,
cover - it wont trap anything if the wind blows up and around.
Wait for spring.
vulcandoc is offline
Storage Tips Amsoil Dealer Group Oil and Lubrication 31 10-28-2012 02:15 PM
Winter Storage NH-Marcus Vulcan 500 18 03-20-2011 09:21 PM
Another winter storage question oquirrhvulcan Vulcan 900 9 11-16-2009 10:49 AM
winter storage meathead Vulcan 900 7 09-15-2009 05:37 AM
Winter Storage??? Merasheen General Vulcan Talk 5 01-09-2009 12:13 PM
