how to oil the chain - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 10-03-2018, 09:23 AM Thread Starter
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
I'm planning a 4000 km trip , and trying to think of how I can oil my chain at motel parking lots, book says oil the chain every 900 km. any ideas? i usually use my bike life to do it at home.
btom is offline
post #2 of 4 (permalink) Old 10-03-2018, 11:50 PM
Evilwestsidefan's Avatar
Year/Make/Model: 1997/Vulcan/Classic
Color: Blue
I just leave on the side stand and just roll it forward a little as I spray lube the chain. It is a stop and go thing but it works fine. You can see where you started lubing because the chain comes back around wet.
Evilwestsidefan is offline
post #3 of 4 (permalink) Old 10-04-2018, 06:31 AM Thread Starter
btom's Avatar
I've been spraying lube on the chain on the top/inside section of the bottom return loop of the chain, do you spray the chain while it's coming around on the rear sprocket?
btom is offline
post #4 of 4 (permalink) Old 10-04-2018, 07:37 PM
Color: Blue
I use the straw the comes with the chain lube to reach under the chain guard and lube while I draw backwards and spray the end of the rear sprocket. Then I move the bike forward and do that again until the lubed chain comes back around. Seems to work OK.
maintenance questions (chain slack and oil change) ddg301 Vulcan 650 S 25 06-13-2018 09:22 PM
clean chain and chain sprockets heathcurrie Engine Work 8 04-10-2012 09:26 AM
Gear/chain rattle sound (not timing chain)? Green Hornet Vulcan 1500 3 08-28-2011 12:49 AM
how to put oil on the chain? mimizone Oil and Lubrication 4 07-18-2009 10:45 PM
Chain Tension Kawasaki Britt Wheels and Tires 2 01-27-2009 08:49 PM
