Pro and Cons of Belt drive on a 96 VN800B - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 09-07-2018, 05:50 PM Thread Starter
Quarry6431's Avatar
Year/Make/Model: 96 VN800B Classic
Displacement/CC's: 800CC
Color: Blue Teal
I have a 96 VN800B Classic that I have been thinking of turning over to a belt drive bike. I know the ride will be smoother and less upkeep but what is the main good point and main Bad point
Quarry6431 is offline
post #2 of 10 (permalink) Old 09-07-2018, 07:17 PM
DESERT ANGEL's Avatar
My 2004 vn2000 has 51000 mile on the original belt the only time it gets attention is when I change the rear tire, I think the key is not to over tighten it I choose belt for street bikes
DESERT ANGEL is offline
post #3 of 10 (permalink) Old 09-07-2018, 08:34 PM Thread Starter
Quarry6431's Avatar
Color: Blue Teal
so from what I am hearing I guess it's a win win situation. Would love the upgrade and the smooth ride.
post #4 of 10 (permalink) Old 09-09-2018, 11:01 AM
Archie's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Blue/Grey
I think the modification can be done , the main isue here is that you have to calculate the right size pulleys in order to match the sprokets ratio , with that done you need to see if the new engine pulley will fit in the space of the engine where the sprocket now resides , and if you have enough clearence for the tire pulley to fit , and finally if there is enough clearence for the belt along the path of the chain . Wish you luck and if you go ahead with the mod tell us how it turned out.
Archie is offline
post #5 of 10 (permalink) Old 09-09-2018, 11:32 AM
VN750Guy**'s Avatar
Year/Make/Model: 2006
Displacement/CC's: 750
Color: Red/black
What is the 800 now: chain or drive shaft?
Chris Cochran
Retired USAF '74 to '95 AMMO
Engine guard with highway pegs
Luggage rack
GPS on RAM handlebar mount
MCCTs replaced ACCTs
Iridium plugs: DPR7EIX-9
Custom made seat (verrry comfortable)
LED turn signals with rear signals relocated
LED license plate holder
Hard mounted Viking saddlebags
Hard mounted fork tool bag (free from Viking)
LED running lights on custom light bar
National Cycles Low Boy Heavy Duty windshield
Home made lowers
VN750Guy** is offline
post #6 of 10 (permalink) Old 09-09-2018, 12:12 PM
Archie's Avatar
Color: Blue/Grey
The specs say it's chain driven , if it is shaft driven then the modification is very likely to be imposible
Archie is offline
post #7 of 10 (permalink) Old 09-09-2018, 05:31 PM Thread Starter
Quarry6431's Avatar
Color: Blue Teal
my 96 is a chain driven....from all the post I read it is possible and the gearing of the two sprockets has been done and tested. Going to do this as a late summer early fall project(meaning in a few weeks it should be all set)
post #8 of 10 (permalink) Old 10-04-2018, 12:08 AM
Evilwestsidefan's Avatar
Year/Make/Model: 1997/Vulcan/Classic
Color: Blue
Not sure what you mean by a smooth ride, I like the chain, I know guys that have the belt on their harleys and when they break it aint good, basically not much warning before failure. All your performance bikes run chains for HP delivery. I run a High Performance chain on my 800 for piece of mind, you just change it out when you run out of adjustment. Only advantage I think a belt might have is a quieter ride, but then I have cobra pipes and wear ear plugs.
Evilwestsidefan is offline
post #9 of 10 (permalink) Old 10-04-2018, 07:24 AM
btom's Avatar
Year/Make/Model: '05
it might be too late for me to warn Quarry about a belt on his 800 since he's probably well into the change from chain to belt, I've done this chain to belt conversion on my first 800, broke the belt twice and the person who bought that 800 from me broke the belt once more and sold the bike. I really don't think the short stroke 800 can use a belt, but if you do go with a belt, ask me first which belt conversion kit NOT to buy, hopefully not the kit that I bought cause the belt is not strong enough and will break.
btom is offline
post #10 of 10 (permalink) Old 10-04-2018, 07:35 PM
Color: Blue
Yep the belts break but the main thing is you get little warning before they fail.
Baron (or Scootworks) Front/Rear Pulleys - Pro and Cons TCRay Vulcan 900 36 04-15-2019 06:57 PM
Voyager Pro and Cons, and Rear Arm Rests? BobinNC General Vulcan Talk 5 02-07-2017 11:19 PM
96 vn800b front fender dailyrider Vulcan 800 1 05-06-2012 11:01 AM
cobra 2-in-1 power pro and power pro hp? redking Vulcan 900 9 03-27-2012 01:44 PM
Why Kawasaki dropped the belt drive in 96? 500hopeful Vulcan 500 11 10-07-2011 06:51 PM
